[petsc-dev] [petsc-maint] FW: Changes to KSPSetOperators in 3.5
Matthew Knepley petsc-maint at mcs.anl.gov
Thu Jan 22 14:54:22 CST 2015
On Thu, Jan 22, 2015 at 2:52 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <petsc-maint at mcs.anl.gov> writes:
> > The SetReusePreconditioner() call does not propagate to sub PCs. Thus, if
> > you use Block-Jacobi, you must call this
> > method on the sub PC as well. Then you should see the previous behavior.
> This sounds like a bug to me.  Unwrapping the appropriate sub-PC is not
> something a user should have to do.
No disagreement here.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150122/8070b1ea/attachment.html>
