[petsc-dev] [petsc-maint] FW: Changes to KSPSetOperators in 3.5
Jed Brown jed at jedbrown.org
Thu Jan 22 14:52:26 CST 2015
Matthew Knepley <petsc-maint at mcs.anl.gov> writes:
> The SetReusePreconditioner() call does not propagate to sub PCs. Thus, if
> you use Block-Jacobi, you must call this
> method on the sub PC as well. Then you should see the previous behavior.
This sounds like a bug to me.  Unwrapping the appropriate sub-PC is not
something a user should have to do.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150122/93fb77f3/attachment.sig>
