[petsc-dev] Differences between injection and interpolation creation
Jed Brown jed at jedbrown.org
Tue Jan 13 12:36:16 CST 2015
Lawrence Mitchell <lawrence.mitchell at imperial.ac.uk> writes:
> Thanks, pull request is here:
> https://bitbucket.org/petsc/petsc/pull-request/245/
> There are a few places where the old VecScatter is used with
> INSERT_VALUES, rather than the ADD_VALUES that MatRestrict gives via
> MatMult.  I pull the scatter context out of the injection Mat to do
> this (although this will obviously fail in the case that the Mat is
> not a MatScatter).
Looks good in general; I commented on the PR.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150113/267972b4/attachment.sig>
