[petsc-dev] Differences between injection and interpolation creation
Lawrence Mitchell lawrence.mitchell at imperial.ac.uk
Tue Jan 13 10:48:15 CST 2015
On 13 Jan 2015, at 16:06, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  I suggest you change the DM to return a matrix in this case and submit a pull request https://bitbucket.org/petsc/petsc/wiki/pull-request-instructions-git then we can get your suggested change into PETSc.
Thanks, pull request is here: https://bitbucket.org/petsc/petsc/pull-request/245/
There are a few places where the old VecScatter is used with INSERT_VALUES, rather than the ADD_VALUES that MatRestrict gives via MatMult.  I pull the scatter context out of the injection Mat to do this (although this will obviously fail in the case that the Mat is not a MatScatter).
Cheers,
Lawrence
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150113/c2e87024/attachment.sig>
