[petsc-dev] log_symmary output to file
Patrick Sanan patrick.sanan at gmail.com
Mon Jan 12 15:29:54 CST 2015
In addition to using
-log_summary FILENAME
to dump text files of the log summary, I've also found the following
very useful recently to dump the log data to python:
-log_view ascii:filename.py:ascii_info_detail
I don't remember the details now, but I submitted a patch somewhat
recently that fixed a minor bug that was preventing me from using this
feature, and it's worked well for me since then.
-Patrick
On 12/01/15 09:58 PM, Dave May wrote:
> This requires the code calls PetscFinalize().
> If you want to get the log summary in a file, at any stage during the
> execution, you can use
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Profiling/PetscLogView.html
> Cheers,
>   Dave
> On Monday, 12 January 2015, Jed Brown <jed at jedbrown.org
> <mailto:jed at jedbrown.org>> wrote:
>     Mark Adams <mfadams at lbl.gov <javascript:;>> writes:
>     > Is there a command line option to send -log_summary stuff to a
>     file instead
>     > of stdout?
>     Did you try -log_summary FILENAME?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150112/f404411d/attachment.html>
