[petsc-dev] log_symmary output to file
Dave May dave.mayhem23 at gmail.com
Mon Jan 12 14:58:20 CST 2015
This requires the code calls PetscFinalize().
If you want to get the log summary in a file, at any stage during the
execution, you can use
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Profiling/PetscLogView.html
Cheers,
  Dave
On Monday, 12 January 2015, Jed Brown <jed at jedbrown.org> wrote:
> Mark Adams <mfadams at lbl.gov <javascript:;>> writes:
> > Is there a command line option to send -log_summary stuff to a file
> instead
> > of stdout?
> Did you try -log_summary FILENAME?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150112/065f1b30/attachment.html>
