[petsc-dev] configuring hypre on batch system
Pierre Jolivet pierre.jolivet at ljll.math.upmc.fr
Fri Jan 9 07:15:49 CST 2015
Maybe you should try to re-configure --with-threadcomm
--with-pthreadclasses and/or --with-openmp, cf.
http://www.mcs.anl.gov/petsc/documentation/installation.html#threads.
Pierre
On 2015-01-09 14:05, Mark Adams wrote:
> Humm, pthread does not work either:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Unknown type. Check for miss-spelling or missing
> package:
> http://www.mcs.anl.gov/petsc/documentation/installation.html#external
> [1]
> [0]PETSC ERROR: Unable to find requested PetscThreadComm type pthread
> [0]PETSC ERROR: See
> http://www.mcs.anl.gov/petsc/documentation/faq.html [2] for trouble
> shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.5.2-1345-g927ffcc
> GIT Date: 2015-01-08 16:04:39 -0700
> [0]PETSC ERROR: ./xgc2 on a arch-titan-opt-pgi named nid07141 by adams
> Fri Jan  9 08:04:32 2015
> [0]PETSC ERROR: Configure options --COPTFLAGS="-mp -fast"
> --CXXOPTFLAGS="-mp -fast" --FOPTFLAGS="-mp -fast" --download-hypre
> --download-metis --download-parmetis --with-cc=cc
> --with-clib-autodetect=0 --with-cxx=CC --with-cxxlib-autodetect=0
> --with-fc=ftn --with-fortranlib-autodetect=0 --with-shared-libraries=0
> --known-mpi-shared-libraries=1 --with-x=0 --with-debugging=0
> PETSC_ARCH=arch-titan-opt-pgi
> PETSC_DIR=/lustre/atlas2/env003/scratch/adams/petsc2
> [0]PETSC ERROR: #1 PetscThreadCommSetType() line 512 in
> /lustre/atlas2/env003/scratch/adams/petsc2/src/sys/threadcomm/interface/threadcomm.c
> [0]PETSC ERROR: #2 PetscThreadCommWorldInitialize() line 1250 in
> [0]PETSC ERROR: #3 PetscGetThreadCommWorld() line 82 in
> [0]PETSC ERROR: #4 PetscCommGetThreadComm() line 117 in
> [0]PETSC ERROR: #5 PetscCommDuplicate() line 195 in
> /lustre/atlas2/env003/scratch/adams/petsc2/src/sys/objects/tagm.c
> On Fri, Jan 9, 2015 at 7:42 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> And is openmp not implemented? I get this:
>> package:
>> [1]
>> [0]PETSC ERROR: Unable to find requested PetscThreadComm type openmp
>> [0]PETSC ERROR: See
>> shooting.
>> [0]PETSC ERROR: ./xgc2 on a arch-titan-opt-pgi named nid09736 by
>> adams Fri Jan 9 07:39:56 2015
>> --with-shared-libraries=0 --known-mpi-shared-libraries=1 --with-x=0
>> --with-debugging=0 PETSC_ARCH=arch-titan-opt-pgi
>> On Fri, Jan 9, 2015 at 12:25 AM, Abhyankar, Shrirang G.
>> <abhyshr at mcs.anl.gov> wrote:
>> Mark,
>> The input for -threadcomm_affinities are the processor numbers
>> So -threadcomm_nthreads 4
>> -threadcomm_affinities 0 1 2 3
>> will pin the 4 threads to processors 0,1,2,3. Unfortunately, there
>> is no standardization of processor number mapping on physical and/or
>> logical cores (it is decided by the OS I think). For example, on one
>> node with two quad-core CPUs (total 8 processors, no
>> hyperthreading), the 1st CPU may have processor numbers 0,1,3,5,
>> while the other 2,4,6,8. On another node with similar hardware, the
>> processor numbers may be 0,1,2,3 on the 1st CPU and 4,5,6,7 on the
>> second. Hence, tools like likwid or hwloc are very helpful for
>> getting the hardware layout. You may also obtain this info by
>> looking at /proc/cupinfo on linux.
>> Shri
>> From: Mark Adams <mfadams at lbl.gov>
>> Date: Thu, 8 Jan 2015 21:43:30 -0500
>> To: barry smith <bsmith at mcs.anl.gov>
>> Cc: petsc-dev mailing list <petsc-dev at mcs.anl.gov>
>> Subject: Re: [petsc-dev] configuring hypre on batch system
>>> -threadcomm_affinities 0 1 2 3 4 5 6 7 ?????
>> I don't know what the flag is here
>> Neither do I. The web page
>> http://www.mcs.anl.gov/petsc/features/threads.html [3] says:
>> -threadcomm_affinities <list_of_affinities>: Sets the core
>> affinities of threads
>> I'm not sure what to put here ...
>>> -threadcomm_type openmp
>>> Then would I get threaded MatVec and other CG + MG stuff? I know
>> this will not be faster but I just need data to corroborate what we
>> all know. And I don't care about setup.
>> Depends on the smoother, we don't have any threaded SOR, if you
>> using Jacobi + Cheyby it will be threaded.
>> Oh right, thanks,
> Links:
> [1]
> [2] http://www.mcs.anl.gov/petsc/documentation/faq.html
> [3] http://www.mcs.anl.gov/petsc/features/threads.html
