[petsc-dev] configuring hypre on batch system
Mark Adams mfadams at lbl.gov
Fri Jan 9 07:05:55 CST 2015
Humm, pthread does not work either:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Unknown type. Check for miss-spelling or missing package:
http://www.mcs.anl.gov/petsc/documentation/installation.html#external
[0]PETSC ERROR: Unable to find requested PetscThreadComm type pthread
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.5.2-1345-g927ffcc  GIT
Date: 2015-01-08 16:04:39 -0700
[0]PETSC ERROR: ./xgc2 on a arch-titan-opt-pgi named nid07141 by adams Fri
Jan  9 08:04:32 2015
[0]PETSC ERROR: Configure options --COPTFLAGS="-mp -fast"
--CXXOPTFLAGS="-mp -fast" --FOPTFLAGS="-mp -fast" --download-hypre
--download-metis --download-parmetis --with-cc=cc --with-clib-autodetect=0
--with-cxx=CC --with-cxxlib-autodetect=0 --with-fc=ftn
--with-fortranlib-autodetect=0 --with-shared-libraries=0
--known-mpi-shared-libraries=1 --with-x=0 --with-debugging=0
PETSC_ARCH=arch-titan-opt-pgi
PETSC_DIR=/lustre/atlas2/env003/scratch/adams/petsc2
[0]PETSC ERROR: #1 PetscThreadCommSetType() line 512 in
/lustre/atlas2/env003/scratch/adams/petsc2/src/sys/threadcomm/interface/threadcomm.c
[0]PETSC ERROR: #2 PetscThreadCommWorldInitialize() line 1250 in
[0]PETSC ERROR: #3 PetscGetThreadCommWorld() line 82 in
[0]PETSC ERROR: #4 PetscCommGetThreadComm() line 117 in
[0]PETSC ERROR: #5 PetscCommDuplicate() line 195 in
/lustre/atlas2/env003/scratch/adams/petsc2/src/sys/objects/tagm.c
On Fri, Jan 9, 2015 at 7:42 AM, Mark Adams <mfadams at lbl.gov> wrote:
> And is openmp not implemented?  I get this:
> [0]PETSC ERROR: Unable to find requested PetscThreadComm type openmp
> for trouble shooting.
> [0]PETSC ERROR: ./xgc2 on a arch-titan-opt-pgi named nid09736 by adams Fri
> Jan  9 07:39:56 2015
> On Fri, Jan 9, 2015 at 12:25 AM, Abhyankar, Shrirang G. <
> abhyshr at mcs.anl.gov> wrote:
>>  Mark,
>>   The input for -threadcomm_affinities are the processor numbers
>>  So -threadcomm_nthreads 4
>>      -threadcomm_affinities 0 1 2 3
>>  will pin the 4 threads to processors 0,1,2,3. Unfortunately, there is
>> no standardization of processor number mapping on physical and/or logical
>> cores (it is decided by the OS I think). For example, on one node with two
>> quad-core CPUs (total 8 processors, no hyperthreading), the 1st CPU may
>> have processor numbers 0,1,3,5, while the other 2,4,6,8. On another node
>> with similar hardware, the processor numbers may be 0,1,2,3 on the 1st CPU
>> and 4,5,6,7 on the second. Hence, tools like likwid or hwloc are very
>> helpful for getting the hardware layout. You may also obtain this info by
>> looking at /proc/cupinfo on linux.
>>  Shri
>>  From: Mark Adams <mfadams at lbl.gov>
>> Date: Thu, 8 Jan 2015 21:43:30 -0500
>> To: barry smith <bsmith at mcs.anl.gov>
>> Cc: petsc-dev mailing list <petsc-dev at mcs.anl.gov>
>> Subject: Re: [petsc-dev] configuring hypre on batch system
>>> > -threadcomm_affinities 0 1 2 3 4 5 6 7  ?????
>>> I    don't know what the flag is here
>>  Neither do I.  The web page
>> http://www.mcs.anl.gov/petsc/features/threads.html says:
>>    -threadcomm_affinities <list_of_affinities>: Sets the core affinities
>>    of threads
>>  I'm not sure what to put here ...
>>> > -threadcomm_type openmp
>>> > Then would I get threaded MatVec and other CG + MG stuff?  I know this
>>> will not be faster but I just need data to corroborate what we all know.
>>> And I don't care about setup.
>>>   Depends on the smoother, we don't have any threaded SOR, if you using
>>> Jacobi + Cheyby it will be threaded.
>>  Oh right, thanks,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150109/6861e325/attachment.html>
