[petsc-dev] ksp/ex56 broken in next
Fri Feb 27 09:35:35 CST 2015
  This has been broken since Jed merged his buggy branch into next. It has been reported to Jed repeatedly.
> On Feb 27, 2015, at 6:45 AM, Mark Adams <mfadams at lbl.gov> wrote:
> Jed, I see this in next, but I am puzzled, I tested a week ago (did I forget to test next?), and I do not see this commit in next, or master, with SourceTree.
> 07:35 (5ab6ef6...)|BISECTING ~/Codes/petsc$ git bisect good
> ee5fc33bea6969d0579ded3dbfac725151deab42 is the first bad commit
> commit ee5fc33bea6969d0579ded3dbfac725151deab42
> Author: Jed Brown <jedbrown at mcs.anl.gov>
> Date:   Wed Dec 4 13:00:40 2013 -0700
>     VecAssembly BTS: enable by default, use -vec_assembly_bts 0 to disable
>     Note that -vec_assembly_bts can only be disabled if VecSetFromOptions is
>     called, which it often is not.  Hopefully the old stash communication
>     routines can be deleted soon, and then all the options go away.
> :040000 040000 388f1fa7e4c763cdb65caf22fa1f42970a73a5e7 7ccce92e0efa7184c23fe507942d273a1ac89665 M      src
