[petsc-dev] ksp/ex56 broken in next
Mark Adams mfadams at lbl.gov
Fri Feb 27 06:45:21 CST 2015
Jed, I see this in next, but I am puzzled, I tested a week ago (did I
forget to test next?), and I do not see this commit in next, or master,
with SourceTree.
07:35 (5ab6ef6...)|BISECTING ~/Codes/petsc$ git bisect good
ee5fc33bea6969d0579ded3dbfac725151deab42 is the first bad commit
commit ee5fc33bea6969d0579ded3dbfac725151deab42
Author: Jed Brown <jedbrown at mcs.anl.gov>
Date:   Wed Dec 4 13:00:40 2013 -0700
    VecAssembly BTS: enable by default, use -vec_assembly_bts 0 to disable
    Note that -vec_assembly_bts can only be disabled if VecSetFromOptions is
    called, which it often is not.  Hopefully the old stash communication
    routines can be deleted soon, and then all the options go away.
:040000 040000 388f1fa7e4c763cdb65caf22fa1f42970a73a5e7
7ccce92e0efa7184c23fe507942d273a1ac89665 M      src
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150227/de022884/attachment.html>
