[petsc-dev] Incident INC0063186 updated -- Update Closed Incident: error building metis on Edison
Wed Feb 18 11:08:16 CST 2015
On Wed, Feb 18, 2015 at 11:04 AM, Mark Adams <mfadams at lbl.gov> wrote:
> I've tried using export CRAYPE_LINK_TYPE=dynamic and using shared
> libraries in PETSc but I had to load gcc 4.8.2, and now I get an error in
> PETSc configuration about incompatible F and C compilers.
Your Fortran compiler is made of sadness:
Executing: ftn  -o
/scratch1/scratchdirs/madams/petsc-bkh5dr/config.compilers/conftest
 -fPIC -fast -no-ipo
/scratch1/scratchdirs/madams/petsc-bkh5dr/config.compilers/conftest.o
/scratch1/scratchdirs/madams/petsc-bkh5dr/config.compilers/confc.o  -ldl
-lstdc++
Possible ERROR while running linker: exit code 256
stderr:
/usr/bin/ld: cannot find -lintlc
   Matt
> On Wed, Feb 18, 2015 at 11:49 AM, NERSC Consulting and Support <
> nersc at service-now.com> wrote:
>> Short description: Update Closed Incident: error building metis on Edison
>> Click here to view incident: INC0063186
>> <https://nersc.service-now.com/nav_to.do?uri=incident.do%3Fsys_id=23d32af16f16710016fb68826e3ee4e1%26sysparm_stack=incident_list.do%3Fsysparm_query=active=true>
>> Comments:
>> 2015-02-18 08:49:07 - Scott French (Additional comments)
>> Dear Mark,
>> Thanks for the heads-up! I will look into this and get back to you soon.
>> Best regards,
>> Scott French
>> NERSC User Services
>> 2015-02-18 08:04:40 - Mark Adams (Additional comments)
>> Created by reply to closed incident INC0062690
>> reply from: mfadams at lbl.gov
>> Well, this error seems to have come back on Edison. I am using camke
>> 2.8.11.2
>> (see log attached).
>> Mark
>> On Mon, Feb 9, 2015 at 6:34 PM,
>> Ref:MSG0597502
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150218/c42fd454/attachment.html>
