[petsc-dev] Incident INC0063186 updated -- Update Closed Incident: error building metis on Edison
Mark Adams mfadams at lbl.gov
Wed Feb 18 11:04:15 CST 2015
I've tried using export CRAYPE_LINK_TYPE=dynamic and using shared libraries
in PETSc but I had to load gcc 4.8.2, and now I get an error in PETSc
configuration about incompatible F and C compilers.
On Wed, Feb 18, 2015 at 11:49 AM, NERSC Consulting and Support <
nersc at service-now.com> wrote:
> Short description: Update Closed Incident: error building metis on Edison
> Click here to view incident: INC0063186
> <https://nersc.service-now.com/nav_to.do?uri=incident.do%3Fsys_id=23d32af16f16710016fb68826e3ee4e1%26sysparm_stack=incident_list.do%3Fsysparm_query=active=true>
> Comments:
> 2015-02-18 08:49:07 - Scott French (Additional comments)
> Dear Mark,
> Thanks for the heads-up! I will look into this and get back to you soon.
> Best regards,
> Scott French
> NERSC User Services
> 2015-02-18 08:04:40 - Mark Adams (Additional comments)
> Created by reply to closed incident INC0062690
> reply from: mfadams at lbl.gov
> Well, this error seems to have come back on Edison. I am using camke
> 2.8.11.2
> (see log attached).
> Mark
> On Mon, Feb 9, 2015 at 6:34 PM,
> Ref:MSG0597502
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150218/d4e8c838/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150218/d4e8c838/attachment.obj>
