[petsc-dev] How to implement the damped Newton method
Lulu Liu lulu.liu at kaust.edu.sa
Sat Feb 7 02:39:30 CST 2015
X is the current approximate solution, Y is the Newton direction
Step 1. the unknown X=[phi,omega,S], the third component S in [0,1]. Hence,
we firstly compute a multiplier alpha such that
X1= X-alpha*Y, and the component S of X1 is still in [0,1].
In step1, we need access the component S to calculate multiplier.
Step 2. Let the damping factor damp=1;
for n=1:N
    lambda=alpha*damp;
    X1=X-lambda*Y;
     Solve J(X1)Y1 = F(X1);
     if ||Y1||<||Y||
           break;
      else
            damp = damp/2;
       end
endfor
the norm || || is weighted norm, and we need access each component and
compute some weights based on each component.
How to implement the damped Newton method above? Is it a easier way to do
it?
Thanks!
This message and its contents, including attachments are intended solely
for the original recipient. If you are not the intended recipient or have
received this message in error, please notify me immediately and delete
this message from your computer system. Any unauthorized use or
distribution is prohibited. Please consider the environment before printing
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150207/23e6251d/attachment.html>
