[petsc-dev] SuperLU build error
Garth N. Wells gnw20 at cam.ac.uk
Fri Dec 18 10:23:42 CST 2015
On 18 December 2015 at 16:10, Jeff Hammond <jeff.science at gmail.com> wrote:
> Are you intentionally turning printf security warnings into errors for an
> HPC code or is that the default setting for PETSc? Or perhaps GCC enables
> that by default now?
It's the default with the Ubuntu MPICH package.
Garth
> Jeff
> On Thursday, December 17, 2015, Garth N. Wells <gnw20 at cam.ac.uk> wrote:
>> I've reported before that SuperLU has a bug that causes compile failures:
>>   util.c:32:18: error: format not a string literal and no format
>> arguments [-Werror=format-security]
>>        fprintf(stderr, msg);
>> I usually fix this by hand, but the way PETSc since very recently resets
>> user changes in cloned external packages is overwriting the change I make.
>> There is a similar bug in SuperLU_dist that I also fix by hand.
>> Garth
> Jeff Hammond
> http://jeffhammond.github.io/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151218/57969bfd/attachment.html>
