[petsc-dev] SuperLU build error
Jeff Hammond jeff.science at gmail.com
Fri Dec 18 10:10:09 CST 2015
Are you intentionally turning printf security warnings into errors for an
HPC code or is that the default setting for PETSc? Or perhaps GCC enables
that by default now?
Jeff
On Thursday, December 17, 2015, Garth N. Wells <gnw20 at cam.ac.uk> wrote:
> I've reported before that SuperLU has a bug that causes compile failures:
>   util.c:32:18: error: format not a string literal and no format arguments
> [-Werror=format-security]
>        fprintf(stderr, msg);
> I usually fix this by hand, but the way PETSc since very recently resets
> user changes in cloned external packages is overwriting the change I make.
> There is a similar bug in SuperLU_dist that I also fix by hand.
> Garth
Jeff Hammond
http://jeffhammond.github.io/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151218/a11ce329/attachment.html>
