[petsc-dev] Including petsc.h breaks user code
Tue Sep 16 09:32:47 CDT 2014
On Tue, Sep 16, 2014 at 8:28 AM, Pierre Jolivet <jolivet at ann.jussieu.fr>
wrote:
> On 2014-09-15 11:40, Matthew Knepley wrote:
>> On Sun, Sep 14, 2014 at 8:36 PM, Barry Smith <bsmith at mcs.anl.gov>
>> wrote:
>>  Pierre,
>>> Thanks for reporting this, it is, indeed our bug. In
>>> petsclog.h we have macros for the various MPI calls in order to log
>>> their usage, for example,
>>> #define
>>>  MPI_Scatter(sendbuf,sendcount,sendtype,recvbuf,recvcount,
>> recvtype,root,comm)
>>> ((petsc_scatter_ct++,0) ||
>>> PetscMPITypeSize(&petsc_recv_len,recvcount,recvtype) ||
>> recvtype,root,comm))
>>> but PetscMPITypeSize() simply called MPI_Type_size() which
>>> generated an MPI error for MPI_DATATYPE_NULL
>>> PETSC_STATIC_INLINE PetscErrorCode PetscMPITypeSize(PetscLogDouble
>>> *buff,PetscMPIInt count,MPI_Datatype type)
>>> PetscMPIInt mysize; return (MPI_Type_size(type,&mysize) ||
>>> ((*buff += (PetscLogDouble) (count*mysize)),0));
>> What error did you get? Why did I not get this error when I ran it? I
>> ran with MPICH 3.0.4 since that was the one I had compiled for C++.
> (sorry for the late answer)
> $ mpicxx in-place.cpp  -I$PETSC_DIR/include -I$PETSC_DIR/$PETSC_ARCH/include
> -L$PETSC_DIR/$PETSC_ARCH/lib -lpetsc -DPETSC_BUG
> $ mpirun -np 4 ./a.out
> Fatal error in PMPI_Type_size: Invalid datatype, error stack:
> PMPI_Type_size(117): MPI_Type_size(MPI_DATATYPE_NULL) failed
> PMPI_Type_size(67).: Datatype for argument datatype is a null datatype
> $ mpicxx -show
> g++ -I/opt/mpich-3.1/build/include -L/opt/mpich-3.1/build/lib -lmpichcxx
> -Wl,-rpath -Wl,/opt/mpich-3.1/build/lib -lmpich -lopa -lmpl -lrt -lpthread
Thanks for tracking this down. This seems to be a change from MPICH 3.0.4
to 3.1 Luckily, Barry found it too.
  Matt
> Pierre
>>   Matt
>>  In the branch barry/fix-usage-with-mpidatatypenull I have added a
>>> check for this special case and avoid the MPI_Type_size() call. I
>>> will put this branch into next and if all tests pass it will be
>>> merged into maint and master and be in the next patch release.
>>> Thank you for reporting the problem.
>>> Barry
>>> Barry still thinks MPI 1.1 is the height of HPC computing :-(
>>> On Sep 14, 2014, at 4:16 PM, Pierre Jolivet
>>> <jolivet at ann.jussieu.fr> wrote:
>>>  Hello,
>>>> Could you please explain to me why the following example is not
>>> working properly when <petsc.h> (from master, with OpenMPI 1.8.1) is
>>> included ?
>>> -I$PETSC_DIR/$PETSC_ARCH/include -L$PETSC_DIR/$PETSC_ARCH/lib
>>> -lpetsc
>>>> $ mpirun -np 2 ./a.out
>>>> Done with the scatter !
>>>> 0 0 0 0 (this line should be filled with 0)
>>>> 1 1 1 1 (this line should be filled with 1)
>>>> Done with the gather !
>>> -lpetsc -DPETSC_BUG
>>>> [:3367] *** An error occurred in MPI_Type_size
>>>> [:3367] *** reported by process [4819779585,140733193388032]
>>>> [:3367] *** on communicator MPI_COMM_WORLD
>>>> [:3367] *** MPI_ERR_TYPE: invalid datatype
>>>> [:3367] *** MPI_ERRORS_ARE_FATAL (processes in this communicator
>>> will now abort,
>>>> [:3367] *** and potentially your MPI job)
>>>> Thank you for looking,
>>>> Pierre
>>>> <in-place.cpp>
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140916/c30ee1be/attachment.html>
