[petsc-dev] Including petsc.h breaks user code
Pierre Jolivet jolivet at ann.jussieu.fr
Tue Sep 16 08:28:30 CDT 2014
On 2014-09-15 11:40, Matthew Knepley wrote:
> On Sun, Sep 14, 2014 at 8:36 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>> Pierre,
>> Thanks for reporting this, it is, indeed our bug. In
>> petsclog.h we have macros for the various MPI calls in order to log
>> their usage, for example,
>> #define
> MPI_Scatter(sendbuf,sendcount,sendtype,recvbuf,recvcount,recvtype,root,comm)
>> ((petsc_scatter_ct++,0) ||
>> PetscMPITypeSize(&petsc_recv_len,recvcount,recvtype) ||
> MPI_Scatter(sendbuf,sendcount,sendtype,recvbuf,recvcount,recvtype,root,comm))
>> but PetscMPITypeSize() simply called MPI_Type_size() which
>> generated an MPI error for MPI_DATATYPE_NULL
>> PETSC_STATIC_INLINE PetscErrorCode PetscMPITypeSize(PetscLogDouble
>> *buff,PetscMPIInt count,MPI_Datatype type)
>> PetscMPIInt mysize; return (MPI_Type_size(type,&mysize) ||
>> ((*buff += (PetscLogDouble) (count*mysize)),0));
> What error did you get? Why did I not get this error when I ran it? I
> ran with MPICH 3.0.4 since that was the one I had compiled for C++.
(sorry for the late answer)
$ mpicxx in-place.cpp  -I$PETSC_DIR/include
-I$PETSC_DIR/$PETSC_ARCH/include -L$PETSC_DIR/$PETSC_ARCH/lib -lpetsc
-DPETSC_BUG
$ mpirun -np 4 ./a.out
Fatal error in PMPI_Type_size: Invalid datatype, error stack:
PMPI_Type_size(117): MPI_Type_size(MPI_DATATYPE_NULL) failed
PMPI_Type_size(67).: Datatype for argument datatype is a null datatype
$ mpicxx -show
g++ -I/opt/mpich-3.1/build/include -L/opt/mpich-3.1/build/lib -lmpichcxx
-Wl,-rpath -Wl,/opt/mpich-3.1/build/lib -lmpich -lopa -lmpl -lrt
-lpthread
Pierre
>   Matt
>> In the branch barry/fix-usage-with-mpidatatypenull I have added a
>> check for this special case and avoid the MPI_Type_size() call. I
>> will put this branch into next and if all tests pass it will be
>> merged into maint and master and be in the next patch release.
>> Thank you for reporting the problem.
>> Barry
>> Barry still thinks MPI 1.1 is the height of HPC computing :-(
>> On Sep 14, 2014, at 4:16 PM, Pierre Jolivet
>> <jolivet at ann.jussieu.fr> wrote:
>>> Hello,
>>> Could you please explain to me why the following example is not
>> working properly when <petsc.h> (from master, with OpenMPI 1.8.1) is
>> included ?
>> -lpetsc
>>> $ mpirun -np 2 ./a.out
>>> Done with the scatter !
>>> 0 0 0 0 (this line should be filled with 0)
>>> 1 1 1 1 (this line should be filled with 1)
>>> Done with the gather !
>> -lpetsc -DPETSC_BUG
>>> [:3367] *** An error occurred in MPI_Type_size
>>> [:3367] *** reported by process [4819779585,140733193388032]
>>> [:3367] *** on communicator MPI_COMM_WORLD
>>> [:3367] *** MPI_ERR_TYPE: invalid datatype
>>> [:3367] *** MPI_ERRORS_ARE_FATAL (processes in this communicator
>> will now abort,
>>> [:3367] *** and potentially your MPI job)
>>> Thank you for looking,
>>> Pierre
>>> <in-place.cpp>
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
