[petsc-dev] so Bitbucket and git suck once again
Jed Brown jed at jedbrown.org
Thu Sep 11 19:05:36 CDT 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
>   Jed
>   So, I am in my PETSc repository and want to try out Patrick Sanan’s FCG since it is cool and we ignored it too long and need to get it into the repository. He’s made a nice pull request; great. So I do
> ~/Src/petsc  master $ git checkout psanan/ksp-fcg
> error: pathspec 'psanan/ksp-fcg' did not match any file(s) known to git.
The branch is in his repository, not ours.  Bitbucket has a major
pull-request permissions problem in that he can make a PR to our
repository without giving us read access to his repository.  This sounds
crazy and it is.  Supposedly we would be able to merge using the web
interface (if not for merge conflicts), but we can't even read the
commits on the web:
  https://bitbucket.org/petsc/petsc/pull-request/197/kspfcg/commits
If we had read access to his repository, I would run:
  git fetch git at bitbucket.org:psanan/petsc psanan/ksp-fcg:psanan/ksp-fcg
to create a local branch in my repository named psanan/ksp-fcg.  I would
then
  ... browse, run tests, etc
  git push -u origin psanan/ksp-fcg
and merge if it looks good.
> Then I fucking give up.
> Why doesn’t bitbucket produce useful information to get his branch without being a git guru? It should show the exact magical git incantation to pull his branch.
> 1) How do I pull his branch into my repository
> 2) How do I know in the future when I want to do this again, how to pull his branch in when my long term memory is shot?
Bitbucket is seriously dropping the ball on this interface.  GitHub
email notifications include the command to pull (merging into the
current branch, so not quite what we want) and have solved the
permissions problem.  They also makes the PR branches available under
refs/pull/*, so that you can get them without using the URL for the
contributor's repo.
Patrick, you have write access to the PETSc repository.  Can you just
push your branches there instead of your personal repo when creating a
PR?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140911/c802cc73/attachment.sig>
