[petsc-dev] updates to handling of external packages
Wed Sep 10 17:16:20 CDT 2014
   PETSc developers,
    As many of you know I have been cleaning up the PETSc handling of external packages including the support for —download-xxxx. I am close to being done, the major changes are
1) there is no distinction between “PETSc” and BuildSystem packages, they are now all in config/BuildSystem/config/packages
2) the PETSc.package.NewPackage is gone
3) All external packages that configure with GNU configure are now derived off the GNUPackage class and
    those that configure with CMake are derived off the CMakePackage class; this eliminated a bunch of redundant cute and pasted code
4) I simplified the GNUPackage, removing a bunch of unneeded methods
5) I removed a bunch of dead packages
6) When installing to a —prefix location the external packages install directly there instead of first too PETSC_ARCH and then getting moved there when PETSc is installed; this means —prefix works for all packages now including MPICH and OpenMP. When —prefix is in a system location, the person installing will be prompted for the sudo password for the installs; this is not ideal but seems the lessor evil
7) the consistency checking is not as good as before but can be improved per package as we find issues.
  If all goes well with next for a while, this will go into master and be, more or less transparent except for bugs that come up. I am hoping these changes will make maintenance and support easier in the future.
  Barry
  For fun I’ve listed below the “configure” options needed by the various packages for just two items: MPI and 64 bit integers. This is a little peephole into why the HPC software ecosystem is so dang frustrating.
  Configuring package for MPI
  GNU configure packages
PETSc                      -with-mpi-dir     OR   --with-mpi-lib --with-mpi-include
Sundials                   --with-mpi-root   OR  --with-mpi-incdir --with-mpi-libdir --with-mpi-libs
Zoltan                      same
MOAB                       --with-mpi=directory
hypre                                              --with-MPI-include --with-MPI-lib-dirs --with-MPI-libs
fftw                       MPICC=
hdf5                       --enable-parallel
Netcfd                     Just knows?
ml                                          --enable-mpi  --with-mpi-libs  and pass -I/MPI includes through --with-cflags and --with-cxxflags
mpe                        MPI_CFLAGS=    MPI_CC=
  CMake packages
ParMetis                  just assumes compiler is MPICC?
Elemental                 -DMPI_C_COMPILER= -DMPI_CXX_COMPILER=
  Other packages
SuperLU_dist              IMPI=      MPILIB=
MUMPS                     INCPAR=-I/MPI includes    LIBPAR=MPI libraries
PTScotch                  CFLAGS=-I/MPI includes    LDFLAGS=MPI libraries
PasTix                    CCFOPT=-I/MPI include MPCCPROG=mpicc compiler
  Configuring packages for 64 bit integers
PETSc                      -with-64-bit-indices
Sundials                   NO SUPPORT
Zoltan                     --with-id-type=ulonglong
MOAB                       ???
hypre                      --enable-bigint
fftw                       ???
hdf5                       Hardwired to be size_t
Netcfd
ml                         NO SUPPORT
  CMake packages
ParMetis                  -DMETIS_USE_LONGINDEX=1
Elemental                 -DUSE_64BIT_INTS=ON
  Other packages
SuperLU_dist              -D_LONGINT
MUMPS                      NO PROPER SUPPORT
PTScotch                  -DINTSIZE64
PasTix                    VERSIONINT=_int64 CCTYPES=-DFORCE_INT64
