[petsc-dev] configure default to --with-etags=0 ?
Mon Sep 8 18:30:53 CDT 2014
On Mon, 8 Sep 2014, Satish Balay wrote:
> On Mon, 8 Sep 2014, Jed Brown wrote:
> I guess I should look at speeding up etags [for usage from a git repo]
> > > balay at es^/scratch/balay/petsc(maint) $ date;make alletags; date
> > > Mon Sep  8 15:12:42 CDT 2014
> > > Mon Sep  8 15:14:49 CDT 2014
Currently etags is invoked in each dir in the source tree.
I've changed the code to get file list from each source dir, but
invoke the command only once [from PETSC_DIR]. This is much faster.
balay at es^/scratch/balay/petsc(maint) $ date; make alletags;date
Mon Sep  8 18:03:30 CDT 2014
Mon Sep  8 18:03:37 CDT 2014
i.e reduced time from 2-3min to 7sec
However there is some difference in output.
balay at es^/scratch/balay/petsc/include(maint) $ etags makefile
balay at es^/scratch/balay/petsc/include(maint) $ cat TAGS
makefile,121
CFLAGS2,1
FFLAGS3,12
SOURCEC4,23
SOURCEF5,34
SOURCEH6,45
LIBBASE7,67
DIRS8,90
LOCDIR9,124
MANSEC10,144
balay at es^/scratch/balay/petsc/include(maint) $ etags ./makefile
makefile,12
CFLAGS2,1
In the first case etags is processing 'makefile' as
--language=makefile. But in the second - case - its unable to infer
that info :(
Satish
