[petsc-dev] 'master' RESET after bad merge! - 'tisaac/thplex' was based on 'next'
Wed Sep 3 14:07:34 CDT 2014
On Wed, Sep 3, 2014 at 2:05 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > You are saying:
> >   - This is a sensible policy
> >   - It would improve our workflow
> We made it a year and a half without botching this.  If we're merging
> branches without checking what we're merging, we've got way bigger
> problems.  And Git is not going to do code review on its own.
This is truly a low point for your argument. You are not arguing against the
usefulness, nor that automation is better than doing it by hand, but that it
did not happen for a while and moral use of VC dictates that you do it
manually?
That is crazy.
   Matt
> > but
> >   - Automating it is too hard, so people should do it by hand
> We're really talking about code review.  If you review what you are
> merging, then there is no "by hand".  The particular policy no-no is
> just one of many incorrect merges that one could do.
> > You come to this conclusion because
> >   - It is hard to do in Git, as currently conceived
> > It is not a stretch to call this a cop out. I would seriously question
> the
> > legitimacy of a model
> > which cannot do this very simple and useful thing.
> Define the thing you want in a precise and generic way.  Make a concrete
> proposal and we can talk about whether that is better than what we have
> now.  Throwing away something good so that we can avoid repeating a
> mistake is unproductive reactionary policy.  I do not think this mistake
> is that hard to avoid and I think that preventing it via technical means
> is unlikely to be an overall improvement.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140903/7eadf327/attachment.html>
