[petsc-dev] 'master' RESET after bad merge! - 'tisaac/thplex' was based on 'next'
Patrick Sanan patrick.sanan at gmail.com
Wed Sep 3 07:21:56 CDT 2014
On 9/3/14 1:05 PM, Matthew Knepley wrote:
> On Tue, Sep 2, 2014 at 10:36 PM, Jed Brown <jed at jedbrown.org
> <mailto:jed at jedbrown.org>> wrote:
>     Barry Smith <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>> writes:
>     > On Sep 2, 2014, at 8:46 AM, Jed Brown <jed at jedbrown.org
>     >> Matt, when you merged 'tisaac/thplex', you got thousands of merge
>     >> commits to 'next' that should never be in 'master'.  I have reset
>     >> 'master' to get it out of there (everything else that was in
>     'master' is
>     >> there now).  This means that any recent topic branches will
>     need to be
>     >> rebased and any updated 'master' will need to be reset to
>     >> 'origin/master'.  Fix 'master' first:
>     >>  git fetch
>     >>  git checkout master
>     >>  git reset --hard origin/master
>     >    Jed, please is there a way to automate this. Relying on people
>     >    getting to the second paragraph of an email and actually
>     following
>     >    the directions properly seems a pretty weak “software process”.
>     This is never supposed to be necessary.  I think this is the first
>     time
>     and if Matt looks at his merges, we shouldn't ever need to do it
>     again. ;-)
> But this was my whole point in our process discussion. Tools should
> subtract
> from what we have to worry about, not add to the cognitive load. We should
> all be manually checking for less, not more. A good tool would prevent any
> merges to master from a branch that was created from next. This seems like
> the simplest requirement to me.
Should this be possible with git hooks? I've never had occasion to use
them but naively, I'd want to do something like create a commit in
'next' which is tagged 'NeverMergeToMaster' and then set up a hook which
will automatically reject any merge to master including a commit with
that tag. The practicalities aren't clear to me, though, since as far as
I can tell BitBucket doesn't give you direct access to hooks, which you
would probably need to employ a strategy like this one:
http://stackoverflow.com/questions/13381105/git-hook-to-prevent-an-experimental-branch-pushed-to-a-release-or-master-branch
>    Matt
>     >> To rebase a topic branch that was started in the last few days
>     (after
>     >> 'tisaac/thplex' was merged; if you started before that merge,
>     you don't
>     >> need to do anything),
>     >    How do I know if I started it before or after the tragic event?
>       git log --grep tisaac/thplex
>     If your history contains the merge, you should rebase.
>     >> check it out, look through recent history to find
>     >    How do I check through the recent history?
>     git log
>     >> the commit on 'master' that you started from (NOT part of your
>     work).
>     >> Suppose that commit is abcd1234.
>     >    How do I know what that commit is?
>     When you look at "git log", it will be the first commit that is
>     not one
>     you wrote for your topic branch.
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140903/c665b521/attachment.html>
