[petsc-dev] configure error
Thu Oct 23 07:39:41 CDT 2014
Fixed
I botched a manual merge
> On Oct 23, 2014, at 7:31 AM, Stefano Zampini <stefano.zampini at gmail.com> wrote:
> just pulled from master (I'm using python 2.7.8)
>              Configuring PETSc to compile on your system
>         CONFIGURATION CRASH  (Please send configure.log to petsc-maint at mcs.anl.gov)
> global name 'PETSc' is not defined
>   File "/fermi/home/userinternal/szampini/petsc/config/configure.py", line 269, in petsc_configure
>     framework = config.framework.Framework(['--configModules=PETSc.Configure','--optionsModule=config.compilerOptions']+sys.argv[1:], loadArgDB = 0)
>   File "/fermi/home/userinternal/szampini/petsc/config/BuildSystem/config/framework.py", line 110, in __init__
>     self.createChildren()
>   File "/fermi/home/userinternal/szampini/petsc/config/BuildSystem/config/framework.py", line 319, in createChildren
>     self.getChild(moduleName)
>   File "/fermi/home/userinternal/szampini/petsc/config/BuildSystem/config/framework.py", line 304, in getChild
>     config.setupDependencies(self)
>   File "/fermi/home/userinternal/szampini/petsc/config/PETSc/Configure.py", line 89, in setupDependencies
>     utilityObj                    = self.framework.require('config.packages.'+utilityName, self)
>   File "/fermi/home/userinternal/szampini/petsc/config/BuildSystem/config/framework.py", line 324, in require
>     config = self.getChild(moduleName, keywordArgs)
>   File "/fermi/home/userinternal/szampini/petsc/config/BuildSystem/config/framework.py", line 298, in getChild
>     config = type(self, *keywordArgs)
>   File "/fermi/home/userinternal/szampini/petsc/config/BuildSystem/config/packages/sowing.py", line 6, in __init__
>     PETSc.package.NewPackage.__init__(self, framework)
> Stefano
