[petsc-dev] configure error
Stefano Zampini stefano.zampini at gmail.com
Thu Oct 23 07:31:28 CDT 2014
just pulled from master (I'm using python 2.7.8)
             Configuring PETSc to compile on your system
        CONFIGURATION CRASH  (Please send configure.log to
petsc-maint at mcs.anl.gov)
global name 'PETSc' is not defined
  File "/fermi/home/userinternal/szampini/petsc/config/configure.py", line
269, in petsc_configure
    framework =
config.framework.Framework(['--configModules=PETSc.Configure','--optionsModule=config.compilerOptions']+sys.argv[1:],
loadArgDB = 0)
  File
"/fermi/home/userinternal/szampini/petsc/config/BuildSystem/config/framework.py",
line 110, in __init__
    self.createChildren()
  File
line 319, in createChildren
    self.getChild(moduleName)
  File
line 304, in getChild
    config.setupDependencies(self)
  File "/fermi/home/userinternal/szampini/petsc/config/PETSc/Configure.py",
line 89, in setupDependencies
    utilityObj                    =
self.framework.require('config.packages.'+utilityName, self)
  File
line 324, in require
    config = self.getChild(moduleName, keywordArgs)
  File
line 298, in getChild
    config = type(self, *keywordArgs)
  File
"/fermi/home/userinternal/szampini/petsc/config/BuildSystem/config/packages/sowing.py",
line 6, in __init__
    PETSc.package.NewPackage.__init__(self, framework)
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141023/ebb68809/attachment.html>
