[petsc-dev] I don't like the location of cmakeboot.py cmakegen.py
Jed Brown jed at jedbrown.org
Wed Oct 1 16:17:34 CDT 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
>   cmakeboot.py is used by stuff in config, so should it really be
>   outside of config?  Can the cmakegen.py stuff be reorganized like
>   the conf/gmakegen.py so that it is not called at all by configure,
>   but is suitably triggered by a make cmake ?
We can.  CMake errors (like hanging or error 256) would show up in "make
cmake".  If we don't mind the 2-second cost of cmakegen, we could just
run it every time.  Otherwise we need an acceptable make rule for the
dependency.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141001/d1199ff5/attachment.sig>
