[petsc-dev] lots o' dead code in BuildSystem
Aron Ahmadia aron at ahmadia.net
Wed Oct 1 06:45:53 CDT 2014
Vulture is a static code analyzer, so it's going to miss anything that's
dynamically instantiated.
On Wed, Oct 1, 2014 at 6:31 AM, Matthew Knepley <knepley at gmail.com> wrote:
> Lots of this is just unused code paths in that particular configure.
> However, we
> can probably eliminate the 'build' directory, BiudlSystem.sourceDatabase
> and PETSc.FEM
>    Matt
> On Tue, Sep 30, 2014 at 11:11 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> ~/Src/petsc  barry/remove-sidl $ Vulture config
>> config/builder.py:605: Unused variable 'comparsion'
>> config/builder.py:639: Unused function 'extractTests'
>> config/builder.py:663: Unused attribute 'cmd'
>> config/builder.py:684: Unused attribute 'ret'
>> config/builder.py:684: Unused attribute 'store'
>> config/builder.py:704: Unused function 'updateNode'
>> config/builder.py:1093: Unused attribute 'memAlign'
>> config/builder.py:1250: Unused attribute 'operationFailed'
>> config/builder.py:1290: Unused function 'compileCUDA'
>> config/builder.py:1293: Unused function 'compileCxx'
>> config/builder.py:1296: Unused function 'compileFortran'
>> config/builder.py:1342: Unused function 'compileCParallel'
>> config/builder.py:1345: Unused function 'compileCxxParallel'
>> config/builder.py:1348: Unused function 'compileFortranParallel'
>> config/builder.py:1374: Unused function 'expandArchive'
>> config/builder.py:1677: Unused function 'checkTestOutput'
>> config/builder.py:1680: Unused function 'checkTestOutputSolver'
>> config/builder.py:1777: Unused function 'buildEtags'
>> config/BuildSystem/args.py:69: Unused attribute '_setCommandLine'
>> config/BuildSystem/build/buildGraph.py:71: Unused function
>> 'removeSubgraph'
>> config/BuildSystem/build/compile/C.py:6: Unused attribute 'usingC'
>> config/BuildSystem/build/compile/Cxx.py:6: Unused attribute 'usingCxx'
>> config/BuildSystem/build/compile/F90.py:6: Unused attribute 'usingF90'
>> config/BuildSystem/build/fileset.py:181: Unused class
>> 'RootedExtensionFileSet'
>> config/BuildSystem/build/fileState.py:61: Unused class 'GenericTag'
>> config/BuildSystem/build/fileState.py:106: Unused class 'Update'
>> config/BuildSystem/build/framework.py:27: Unused attribute 'directories'
>> config/BuildSystem/build/framework.py:78: Unused function
>> 'makeSourceDBPathsAbsolute'
>> config/BuildSystem/build/framework.py:87: Unused function
>> 'makeSourceDBPathsRelative'
>> config/BuildSystem/build/framework.py:103: Unused variable 'newTmp'
>> config/BuildSystem/build/framework.py:177: Unused function 't_activate'
>> config/BuildSystem/build/framework.py:184: Unused function 't_deactivate'
>> config/BuildSystem/build/framework.py:195: Unused function 't_configure'
>> config/BuildSystem/build/framework.py:259: Unused function 't_compile'
>> config/BuildSystem/build/framework.py:264: Unused function
>> 't_compilePrograms'
>> config/BuildSystem/build/framework.py:271: Unused function 't_install'
>> config/BuildSystem/build/framework.py:290: Unused function 't_uninstall'
>> config/BuildSystem/build/framework.py:306: Unused function 't_citool'
>> config/BuildSystem/build/framework.py:312: Unused function 't_push'
>> config/BuildSystem/build/framework.py:321: Unused function 't_pull'
>> config/BuildSystem/build/framework.py:331: Unused function 't_makeStamp'
>> config/BuildSystem/build/framework.py:339: Unused function 't_default'
>> config/BuildSystem/build/framework.py:343: Unused function
>> 't_printTargets'
>> config/BuildSystem/build/framework.py:357: Unused function 't_purge'
>> config/BuildSystem/build/framework.py:374: Unused function 't_update'
>> config/BuildSystem/build/processor.py:341: Unused class
>> 'DirectoryArchiver'
>> config/BuildSystem/build/processor.py:386: Unused class 'Archiver'
>> config/BuildSystem/build/processor.py:460: Unused class
>> 'ImportSharedLinker'
>> config/BuildSystem/build/processor.py:507: Unused class 'LibraryAdder'
>> config/BuildSystem/build/transform.py:41: Unused class 'Filter'
>> config/BuildSystem/build/transform.py:59: Unused class 'Remover'
>> config/BuildSystem/build/transform.py:80: Unused class 'Consolidator'
>> config/BuildSystem/config/base.py:189: Unused function
>> 'addArgumentSubstitution'
>> config/BuildSystem/config/base.py:279: Unused function 'getExecutables'
>> config/BuildSystem/config/base.py:658: Unused function 'splitIncludes'
>> config/BuildSystem/config/compile/processor.py:70: Unused function
>> 'pushRequiredFlags'
>> config/BuildSystem/config/compile/processor.py:73: Unused function
>> 'popRequiredFlags'
>> config/BuildSystem/config/compilers.py:21: Unused attribute 'cRestrict'
>> config/BuildSystem/config/compilers.py:22: Unused attribute 'cxxRestrict'
>> config/BuildSystem/config/framework.py:366: Unused function
>> 'updatePackageDependencies'
>> config/BuildSystem/config/framework.py:465: Unused function
>> 'addSubstitutionFile'
>> config/BuildSystem/config/framework.py:938: Unused attribute '_configured'
>> config/BuildSystem/config/package.py:61: Unused attribute 'double'
>> config/BuildSystem/config/package.py:62: Unused attribute 'complex'
>> config/BuildSystem/config/package.py:63: Unused attribute
>> 'requires32bitint'
>> config/BuildSystem/config/package.py:94: Unused attribute 'openmpi'
>> config/BuildSystem/config/package.py:542: Unused variable 'foundLibrary'
>> config/BuildSystem/config/package.py:543: Unused variable 'foundHeader'
>> config/BuildSystem/config/packages/cuda.py:24: Unused attribute
>> 'ThrustVersionStr'
>> config/BuildSystem/config/packages/cuda.py:25: Unused attribute
>> 'CUSPVersionStr'
>> config/BuildSystem/config/packages/MPI.py:46: Unused attribute 'shared'
>> config/BuildSystem/config/packages/MPI.py:48: Unused attribute 'commf2c'
>> config/BuildSystem/config/packages/MPI.py:49: Unused attribute 'commc2f'
>> config/BuildSystem/config/packages/MPI.py:181: Unused attribute
>> 'haveFinalized'
>> config/BuildSystem/config/packages/MPI.py:184: Unused attribute
>> 'haveInPlace'
>> config/BuildSystem/config/packages/MPI.py:188: Unused attribute
>> 'haveTypeCreateStruct'
>> config/BuildSystem/config/packages/MPI.py:193: Unused attribute
>> 'haveCommCreateErrhandler'
>> config/BuildSystem/config/packages/MPI.py:198: Unused attribute
>> 'haveCommSetErrhandler'
>> config/BuildSystem/config/packages/MPI.py:410: Unused attribute
>> 'havef90module'
>> config/BuildSystem/config/packages/mpi4py.py:14: Unused attribute 'numpy'
>> config/BuildSystem/config/packages/mpi4py.py:22: Unused variable 'pp'
>> config/BuildSystem/config/packages/mpi4py.py:24: Unused variable 'apple'
>> config/BuildSystem/config/packages/SuperLU_MT.py:12: Unused attribute
>> 'worksonWindows'
>> config/BuildSystem/config/packages/Triangle.py:28: Unused variable
>> 'installmakeinc'
>> config/BuildSystem/config/python.py:12: Unused attribute 'isShared'
>> config/BuildSystem/config/regression/frameworkTest.py:10: Unused class
>> 'FrameworkTest'
>> config/BuildSystem/config/regression/frameworkTest.py:42: Unused function
>> 'testEmptyConfigure'
>> config/BuildSystem/config/regression/frameworkTest.py:47: Unused function
>> 'testLogName'
>> config/BuildSystem/config/regression/frameworkTest.py:54: Unused function
>> 'testFullDefaultConfigure'
>> config/BuildSystem/config/regression/shellTest.py:6: Unused class
>> 'ShellTest'
>> config/BuildSystem/config/regression/shellTest.py:14: Unused function
>> 'testTimeout'
>> config/BuildSystem/config/setCompilers.py:22: Unused attribute
>> 'usedMPICompilers'
>> config/BuildSystem/config/setCompilers.py:622: Unused attribute
>> 'compilerVersionCUDA'
>> config/BuildSystem/config/setCompilers.py:997: Unused attribute 'usePIC'
>> config/BuildSystem/config/setCompilers.py:1020: Unused attribute 'isPIC'
>> config/BuildSystem/config/setCompilers.py:1197: Unused attribute
>> 'staticLinker'
>> config/BuildSystem/config/setCompilers.py:1287: Unused function
>> 'addLinkerFlag'
>> config/BuildSystem/config/setCompilers.py:1373: Unused attribute
>> 'staticLibrary'
>> config/BuildSystem/config/setCompilers.py:1374: Unused attribute
>> 'sharedLibrary'
>> config/BuildSystem/config/setsBackport.py:454: Unused function
>> 'union_update'
>> config/BuildSystem/config/setsBackport.py:464: Unused function
>> 'intersection_update'
>> config/BuildSystem/config/setsBackport.py:541: Unused function 'discard'
>> config/BuildSystem/config/setsOrdered.py:547: Unused function
>> 'updateDuplicate'
>> config/BuildSystem/config/setsOrdered.py:633: Unused class 'SetsTest'
>> config/BuildSystem/config/setsOrdered.py:634: Unused function
>> 'testOrdering'
>> config/BuildSystem/config/setsOrdered.py:640: Unused function
>> 'testUniqueness'
>> config/BuildSystem/config/setsOrdered.py:646: Unused function 'testOrder'
>> config/BuildSystem/config/sourceControl.py:31: Unused attribute
>> 'gitversion'
>> config/BuildSystem/config/sourceControl.py:42: Unused attribute
>> 'hgversion'
>> config/BuildSystem/config/sourceControl.py:51: Unused attribute
>> 'cvxversion'
>> config/BuildSystem/config/sourceControl.py:60: Unused attribute
>> 'svnversion'
>> config/BuildSystem/config/types.py:128: Unused function 'checkFortranStar'
>> config/BuildSystem/maker.py:33: Unused function 'getMake'
>> config/BuildSystem/maker.py:232: Unused class 'BasicMake'
>> config/BuildSystem/nargs.py:5: Unused function 'getInteractive'
>> config/BuildSystem/nargs.py:46: Unused function 'setTemporary'
>> config/BuildSystem/nargs.py:144: Unused function 'getKey'
>> config/BuildSystem/nargs.py:206: Unused class 'ArgFuzzyBool'
>> config/BuildSystem/nargs.py:274: Unused class 'ArgReal'
>> config/BuildSystem/nargs.py:390: Unused class 'ArgExecutable'
>> config/BuildSystem/RDict.py:269: Unused function 'hasType'
>> config/BuildSystem/RDict.py:541: Unused function 'handle'
>> config/BuildSystem/retrieval.py:123: Unused function 'ftpRetrieve'
>> config/BuildSystem/retrieval.py:127: Unused function 'httpRetrieve'
>> config/BuildSystem/retrieval.py:131: Unused function 'fileRetrieve'
>> config/BuildSystem/retrieval.py:135: Unused function 'svnRetrieve'
>> config/BuildSystem/retrieval.py:147: Unused function 'bkUpdate'
>> config/BuildSystem/retrieval.py:217: Unused function 'retrieve'
>> config/BuildSystem/retrieval.py:239: Unused function 'removeRoot'
>> config/BuildSystem/retrieval.py:261: Unused function 'bkfileRetrieve'
>> config/BuildSystem/retrieval.py:266: Unused function 'sshRetrieve'
>> config/BuildSystem/retrieval.py:271: Unused function 'oldRetrieve'
>> config/BuildSystem/script.py:41: Unused attribute 'shell'
>> config/BuildSystem/script.py:83: Unused attribute '_setup'
>> config/BuildSystem/script.py:293: Unused attribute 'outputFiles'
>> config/BuildSystem/script.py:414: Unused function 'setPreprocessorObject'
>> config/BuildSystem/script.py:428: Unused function 'setCompilerObject'
>> config/BuildSystem/script.py:444: Unused function 'setLinkerObject'
>> config/BuildSystem/script.py:476: Unused function 'setDynamicLinkerObject'
>> config/BuildSystem/sourceDatabase.py:185: Unused function 'clearSource'
>> config/BuildSystem/sourceDatabase.py:194: Unused function
>> 'getDependencies'
>> config/BuildSystem/sourceDatabase.py:215: Unused function
>> 'calculateDependencies'
>> config/BuildSystem/sourceDatabase.py:281: Unused class
>> 'DependencyAnalyzer'
>> config/BuildSystem/urlMappingInstalled.py:14: Unused function
>> 'setupUrlMapping'
>> config/cmakeboot.py:22: Unused function 'quoteIfNeeded'
>> config/cmakegen.py:64: Unused function 'unexpected'
>> config/examples/arch-bgp-ibm-opt.py:63: Unused variable 'test_options'
>> config/PETSc/Configure.py:58: Unused attribute 'atomics'
>> config/PETSc/Configure.py:739: Unused variable 'langs'
>> config/PETSc/FEM.py:877: Unused function 'createFaceQuadrature'
>> config/PETSc/FEM.py:904: Unused attribute 'list'
>> config/PETSc/FEM.py:907: Unused attribute 'type'
>> config/PETSc/FEM.py:909: Unused attribute 'static'
>> config/PETSc/FEM.py:910: Unused attribute 'initializer'
>> config/PETSc/FEM.py:923: Unused attribute 'identifier'
>> config/PETSc/FEM.py:924: Unused attribute 'replacementText'
>> config/PETSc/FEM.py:1098: Unused function 'getReferenceTensor'
>> config/PETSc/FEM.py:1357: Unused attribute 'typedef'
>> config/PETSc/FEM.py:1386: Unused function 'getQuadratureSetup'
>> config/PETSc/FEM.py:1394: Unused attribute 'branch'
>> config/PETSc/FEM.py:1449: Unused function 'getIntegratorPoints'
>> config/PETSc/FEM.py:1510: Unused attribute 'caseLabel'
>> config/PETSc/FEM.py:1569: Unused function 'getIntegratorSetup'
>> config/PETSc/FEM.py:1578: Unused function 'getSectionSetup'
>> config/PETSc/FEM.py:1669: Unused function 'getElementIntegrals'
>> config/PETSc/FEM.py:1696: Unused attribute 'parameters'
>> config/PETSc/FEM.py:1758: Unused attribute 'comments'
>> config/PETSc/FEM.py:1814: Unused attribute 'purpose'
>> config/PETSc/FEM.py:1904: Unused function 'runTensorProduct'
>> config/PETSc/utilities/arch.py:54: Unused attribute 'archBase'
>> config/PETSc/utilities/cacheDetails.py:29: Unused attribute 'updated'
>> config/PETSc/utilities/CHUD.py:39: Unused attribute 'haveCHUD'
>> config/PETSc/utilities/libraryOptions.py:33: Unused attribute
>> 'scalarTypes'
>> config/PETSc/utilities/missing.py:86: Unused function
>> 'configureMissingErrnos'
>> config/PETSc/utilities/Regression.py:27: Unused attribute ‘elemental'
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141001/fdcfbf4d/attachment.html>
