[petsc-dev] lots o' dead code in BuildSystem
Wed Oct 1 05:31:24 CDT 2014
Lots of this is just unused code paths in that particular configure.
However, we
can probably eliminate the 'build' directory, BiudlSystem.sourceDatabase
and PETSc.FEM
   Matt
On Tue, Sep 30, 2014 at 11:11 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> ~/Src/petsc  barry/remove-sidl $ Vulture config
> config/builder.py:605: Unused variable 'comparsion'
> config/builder.py:639: Unused function 'extractTests'
> config/builder.py:663: Unused attribute 'cmd'
> config/builder.py:684: Unused attribute 'ret'
> config/builder.py:684: Unused attribute 'store'
> config/builder.py:704: Unused function 'updateNode'
> config/builder.py:1093: Unused attribute 'memAlign'
> config/builder.py:1250: Unused attribute 'operationFailed'
> config/builder.py:1290: Unused function 'compileCUDA'
> config/builder.py:1293: Unused function 'compileCxx'
> config/builder.py:1296: Unused function 'compileFortran'
> config/builder.py:1342: Unused function 'compileCParallel'
> config/builder.py:1345: Unused function 'compileCxxParallel'
> config/builder.py:1348: Unused function 'compileFortranParallel'
> config/builder.py:1374: Unused function 'expandArchive'
> config/builder.py:1677: Unused function 'checkTestOutput'
> config/builder.py:1680: Unused function 'checkTestOutputSolver'
> config/builder.py:1777: Unused function 'buildEtags'
> config/BuildSystem/args.py:69: Unused attribute '_setCommandLine'
> config/BuildSystem/build/buildGraph.py:71: Unused function 'removeSubgraph'
> config/BuildSystem/build/compile/C.py:6: Unused attribute 'usingC'
> config/BuildSystem/build/compile/Cxx.py:6: Unused attribute 'usingCxx'
> config/BuildSystem/build/compile/F90.py:6: Unused attribute 'usingF90'
> config/BuildSystem/build/fileset.py:181: Unused class
> 'RootedExtensionFileSet'
> config/BuildSystem/build/fileState.py:61: Unused class 'GenericTag'
> config/BuildSystem/build/fileState.py:106: Unused class 'Update'
> config/BuildSystem/build/framework.py:27: Unused attribute 'directories'
> config/BuildSystem/build/framework.py:78: Unused function
> 'makeSourceDBPathsAbsolute'
> config/BuildSystem/build/framework.py:87: Unused function
> 'makeSourceDBPathsRelative'
> config/BuildSystem/build/framework.py:103: Unused variable 'newTmp'
> config/BuildSystem/build/framework.py:177: Unused function 't_activate'
> config/BuildSystem/build/framework.py:184: Unused function 't_deactivate'
> config/BuildSystem/build/framework.py:195: Unused function 't_configure'
> config/BuildSystem/build/framework.py:259: Unused function 't_compile'
> config/BuildSystem/build/framework.py:264: Unused function
> 't_compilePrograms'
> config/BuildSystem/build/framework.py:271: Unused function 't_install'
> config/BuildSystem/build/framework.py:290: Unused function 't_uninstall'
> config/BuildSystem/build/framework.py:306: Unused function 't_citool'
> config/BuildSystem/build/framework.py:312: Unused function 't_push'
> config/BuildSystem/build/framework.py:321: Unused function 't_pull'
> config/BuildSystem/build/framework.py:331: Unused function 't_makeStamp'
> config/BuildSystem/build/framework.py:339: Unused function 't_default'
> config/BuildSystem/build/framework.py:343: Unused function 't_printTargets'
> config/BuildSystem/build/framework.py:357: Unused function 't_purge'
> config/BuildSystem/build/framework.py:374: Unused function 't_update'
> config/BuildSystem/build/processor.py:341: Unused class 'DirectoryArchiver'
> config/BuildSystem/build/processor.py:386: Unused class 'Archiver'
> config/BuildSystem/build/processor.py:460: Unused class
> 'ImportSharedLinker'
> config/BuildSystem/build/processor.py:507: Unused class 'LibraryAdder'
> config/BuildSystem/build/transform.py:41: Unused class 'Filter'
> config/BuildSystem/build/transform.py:59: Unused class 'Remover'
> config/BuildSystem/build/transform.py:80: Unused class 'Consolidator'
> config/BuildSystem/config/base.py:189: Unused function
> 'addArgumentSubstitution'
> config/BuildSystem/config/base.py:279: Unused function 'getExecutables'
> config/BuildSystem/config/base.py:658: Unused function 'splitIncludes'
> config/BuildSystem/config/compile/processor.py:70: Unused function
> 'pushRequiredFlags'
> config/BuildSystem/config/compile/processor.py:73: Unused function
> 'popRequiredFlags'
> config/BuildSystem/config/compilers.py:21: Unused attribute 'cRestrict'
> config/BuildSystem/config/compilers.py:22: Unused attribute 'cxxRestrict'
> config/BuildSystem/config/framework.py:366: Unused function
> 'updatePackageDependencies'
> config/BuildSystem/config/framework.py:465: Unused function
> 'addSubstitutionFile'
> config/BuildSystem/config/framework.py:938: Unused attribute '_configured'
> config/BuildSystem/config/package.py:61: Unused attribute 'double'
> config/BuildSystem/config/package.py:62: Unused attribute 'complex'
> config/BuildSystem/config/package.py:63: Unused attribute
> 'requires32bitint'
> config/BuildSystem/config/package.py:94: Unused attribute 'openmpi'
> config/BuildSystem/config/package.py:542: Unused variable 'foundLibrary'
> config/BuildSystem/config/package.py:543: Unused variable 'foundHeader'
> config/BuildSystem/config/packages/cuda.py:24: Unused attribute
> 'ThrustVersionStr'
> config/BuildSystem/config/packages/cuda.py:25: Unused attribute
> 'CUSPVersionStr'
> config/BuildSystem/config/packages/MPI.py:46: Unused attribute 'shared'
> config/BuildSystem/config/packages/MPI.py:48: Unused attribute 'commf2c'
> config/BuildSystem/config/packages/MPI.py:49: Unused attribute 'commc2f'
> config/BuildSystem/config/packages/MPI.py:181: Unused attribute
> 'haveFinalized'
> config/BuildSystem/config/packages/MPI.py:184: Unused attribute
> 'haveInPlace'
> config/BuildSystem/config/packages/MPI.py:188: Unused attribute
> 'haveTypeCreateStruct'
> config/BuildSystem/config/packages/MPI.py:193: Unused attribute
> 'haveCommCreateErrhandler'
> config/BuildSystem/config/packages/MPI.py:198: Unused attribute
> 'haveCommSetErrhandler'
> config/BuildSystem/config/packages/MPI.py:410: Unused attribute
> 'havef90module'
> config/BuildSystem/config/packages/mpi4py.py:14: Unused attribute 'numpy'
> config/BuildSystem/config/packages/mpi4py.py:22: Unused variable 'pp'
> config/BuildSystem/config/packages/mpi4py.py:24: Unused variable 'apple'
> config/BuildSystem/config/packages/SuperLU_MT.py:12: Unused attribute
> 'worksonWindows'
> config/BuildSystem/config/packages/Triangle.py:28: Unused variable
> 'installmakeinc'
> config/BuildSystem/config/python.py:12: Unused attribute 'isShared'
> config/BuildSystem/config/regression/frameworkTest.py:10: Unused class
> 'FrameworkTest'
> config/BuildSystem/config/regression/frameworkTest.py:42: Unused function
> 'testEmptyConfigure'
> config/BuildSystem/config/regression/frameworkTest.py:47: Unused function
> 'testLogName'
> config/BuildSystem/config/regression/frameworkTest.py:54: Unused function
> 'testFullDefaultConfigure'
> config/BuildSystem/config/regression/shellTest.py:6: Unused class
> 'ShellTest'
> config/BuildSystem/config/regression/shellTest.py:14: Unused function
> 'testTimeout'
> config/BuildSystem/config/setCompilers.py:22: Unused attribute
> 'usedMPICompilers'
> config/BuildSystem/config/setCompilers.py:622: Unused attribute
> 'compilerVersionCUDA'
> config/BuildSystem/config/setCompilers.py:997: Unused attribute 'usePIC'
> config/BuildSystem/config/setCompilers.py:1020: Unused attribute 'isPIC'
> config/BuildSystem/config/setCompilers.py:1197: Unused attribute
> 'staticLinker'
> config/BuildSystem/config/setCompilers.py:1287: Unused function
> 'addLinkerFlag'
> config/BuildSystem/config/setCompilers.py:1373: Unused attribute
> 'staticLibrary'
> config/BuildSystem/config/setCompilers.py:1374: Unused attribute
> 'sharedLibrary'
> config/BuildSystem/config/setsBackport.py:454: Unused function
> 'union_update'
> config/BuildSystem/config/setsBackport.py:464: Unused function
> 'intersection_update'
> config/BuildSystem/config/setsBackport.py:541: Unused function 'discard'
> config/BuildSystem/config/setsOrdered.py:547: Unused function
> 'updateDuplicate'
> config/BuildSystem/config/setsOrdered.py:633: Unused class 'SetsTest'
> config/BuildSystem/config/setsOrdered.py:634: Unused function
> 'testOrdering'
> config/BuildSystem/config/setsOrdered.py:640: Unused function
> 'testUniqueness'
> config/BuildSystem/config/setsOrdered.py:646: Unused function 'testOrder'
> config/BuildSystem/config/sourceControl.py:31: Unused attribute
> 'gitversion'
> config/BuildSystem/config/sourceControl.py:42: Unused attribute 'hgversion'
> config/BuildSystem/config/sourceControl.py:51: Unused attribute
> 'cvxversion'
> config/BuildSystem/config/sourceControl.py:60: Unused attribute
> 'svnversion'
> config/BuildSystem/config/types.py:128: Unused function 'checkFortranStar'
> config/BuildSystem/maker.py:33: Unused function 'getMake'
> config/BuildSystem/maker.py:232: Unused class 'BasicMake'
> config/BuildSystem/nargs.py:5: Unused function 'getInteractive'
> config/BuildSystem/nargs.py:46: Unused function 'setTemporary'
> config/BuildSystem/nargs.py:144: Unused function 'getKey'
> config/BuildSystem/nargs.py:206: Unused class 'ArgFuzzyBool'
> config/BuildSystem/nargs.py:274: Unused class 'ArgReal'
> config/BuildSystem/nargs.py:390: Unused class 'ArgExecutable'
> config/BuildSystem/RDict.py:269: Unused function 'hasType'
> config/BuildSystem/RDict.py:541: Unused function 'handle'
> config/BuildSystem/retrieval.py:123: Unused function 'ftpRetrieve'
> config/BuildSystem/retrieval.py:127: Unused function 'httpRetrieve'
> config/BuildSystem/retrieval.py:131: Unused function 'fileRetrieve'
> config/BuildSystem/retrieval.py:135: Unused function 'svnRetrieve'
> config/BuildSystem/retrieval.py:147: Unused function 'bkUpdate'
> config/BuildSystem/retrieval.py:217: Unused function 'retrieve'
> config/BuildSystem/retrieval.py:239: Unused function 'removeRoot'
> config/BuildSystem/retrieval.py:261: Unused function 'bkfileRetrieve'
> config/BuildSystem/retrieval.py:266: Unused function 'sshRetrieve'
> config/BuildSystem/retrieval.py:271: Unused function 'oldRetrieve'
> config/BuildSystem/script.py:41: Unused attribute 'shell'
> config/BuildSystem/script.py:83: Unused attribute '_setup'
> config/BuildSystem/script.py:293: Unused attribute 'outputFiles'
> config/BuildSystem/script.py:414: Unused function 'setPreprocessorObject'
> config/BuildSystem/script.py:428: Unused function 'setCompilerObject'
> config/BuildSystem/script.py:444: Unused function 'setLinkerObject'
> config/BuildSystem/script.py:476: Unused function 'setDynamicLinkerObject'
> config/BuildSystem/sourceDatabase.py:185: Unused function 'clearSource'
> config/BuildSystem/sourceDatabase.py:194: Unused function 'getDependencies'
> config/BuildSystem/sourceDatabase.py:215: Unused function
> 'calculateDependencies'
> config/BuildSystem/sourceDatabase.py:281: Unused class 'DependencyAnalyzer'
> config/BuildSystem/urlMappingInstalled.py:14: Unused function
> 'setupUrlMapping'
> config/cmakeboot.py:22: Unused function 'quoteIfNeeded'
> config/cmakegen.py:64: Unused function 'unexpected'
> config/examples/arch-bgp-ibm-opt.py:63: Unused variable 'test_options'
> config/PETSc/Configure.py:58: Unused attribute 'atomics'
> config/PETSc/Configure.py:739: Unused variable 'langs'
> config/PETSc/FEM.py:877: Unused function 'createFaceQuadrature'
> config/PETSc/FEM.py:904: Unused attribute 'list'
> config/PETSc/FEM.py:907: Unused attribute 'type'
> config/PETSc/FEM.py:909: Unused attribute 'static'
> config/PETSc/FEM.py:910: Unused attribute 'initializer'
> config/PETSc/FEM.py:923: Unused attribute 'identifier'
> config/PETSc/FEM.py:924: Unused attribute 'replacementText'
> config/PETSc/FEM.py:1098: Unused function 'getReferenceTensor'
> config/PETSc/FEM.py:1357: Unused attribute 'typedef'
> config/PETSc/FEM.py:1386: Unused function 'getQuadratureSetup'
> config/PETSc/FEM.py:1394: Unused attribute 'branch'
> config/PETSc/FEM.py:1449: Unused function 'getIntegratorPoints'
> config/PETSc/FEM.py:1510: Unused attribute 'caseLabel'
> config/PETSc/FEM.py:1569: Unused function 'getIntegratorSetup'
> config/PETSc/FEM.py:1578: Unused function 'getSectionSetup'
> config/PETSc/FEM.py:1669: Unused function 'getElementIntegrals'
> config/PETSc/FEM.py:1696: Unused attribute 'parameters'
> config/PETSc/FEM.py:1758: Unused attribute 'comments'
> config/PETSc/FEM.py:1814: Unused attribute 'purpose'
> config/PETSc/FEM.py:1904: Unused function 'runTensorProduct'
> config/PETSc/utilities/arch.py:54: Unused attribute 'archBase'
> config/PETSc/utilities/cacheDetails.py:29: Unused attribute 'updated'
> config/PETSc/utilities/CHUD.py:39: Unused attribute 'haveCHUD'
> config/PETSc/utilities/libraryOptions.py:33: Unused attribute 'scalarTypes'
> config/PETSc/utilities/missing.py:86: Unused function
> 'configureMissingErrnos'
> config/PETSc/utilities/Regression.py:27: Unused attribute ‘elemental'
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141001/42daf585/attachment.html>
