[petsc-dev] DMGetDS in fortran
William Gropp wgropp at illinois.edu
Fri Nov 28 10:39:12 CST 2014
FYI, I’m changing the Fortran stub generator to read a file for these types, so it won’t be necessary to change the code in the stub generator.  Still clunky but one step less so.
Bill
On Nov 28, 2014, at 6:43 AM, Matthew Knepley <knepley at gmail.com> wrote:
> Every time we add a type to PETSc, we have to tell the Fortran stub generator about it. This is a clunky part of the
> design, but there is not enough momentum to change it.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141128/e8f916e4/attachment.html>
