[petsc-dev] DMGetDS in fortran
Fri Nov 28 06:43:52 CST 2014
On Thu, Nov 27, 2014 at 9:19 PM, Adrian Croucher <a.croucher at auckland.ac.nz>
wrote:
> hi
> I'm just getting back to using DMPlex after a few months busy on other
> stuff, and looking at the TS ex11 problem, a few things have changed in the
> meantime.
> TS ex11 used to set up a PetscSection manually to define the data layout,
> for constructing vectors on it. Now it seems this is handled by creating a
> PetscFV object and adding it to the PetscDS in the DMPlex.
> I set up a simplified code to test this in isolation, and it works in C
> but not in Fortran (code below). It gets this error- looks like maybe
> something wrong with the fortran interface:
Every time we add a type to PETSc, we have to tell the Fortran stub
generator about it. This is a clunky part of the
design, but there is not enough momentum to change it. Can you try deleting
your PETSC_ARCH directory and
reconfiguring? FIRST,
  cd $PETSC_DIR
  mv $PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py .
so that you can get the same configuration.
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Null argument, when expecting valid pointer
> [0]PETSC ERROR: Null Pointer: Parameter # 2
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.5.2-1240-gd4bc1ae  GIT
> Date: 2014-11-25 11:37:47 -0600
> [0]PETSC ERROR: ./testplexf on a linux-gnu-c-opt named des108 by acro018
> Fri Nov 28 16:02:22 2014
> [0]PETSC ERROR: Configure options --download-netcdf --download-exodusii
> --with-hdf5-dir=/usr/lib --with-numpy-dir=/usr/lib/pymodules/python2.7/numpy
> with-scientificpython-dir=/usr/lib/python2.7/dist-packages/scipy
> --with-petsc4py-dir=/usr/local/lib/python2.7/dist-packages/petsc4py
> --download-triangl
> e --with-fortran-interfaces=1 --download-ptscotch --download-chaco
> --download-ctetgen
> [0]PETSC ERROR: #1 DMGetDS() line 3407 in /home/acro018/software/PETSc/
> code/src/dm/interface/dm.c
> Also, any chance of a fortran interface to DMPlexCreateFromFile()? It
> appears to be missing at the moment.
Yes, I can add this.
    Matt
> Regards, Adrian
> program testplex
>   implicit none
> #include <finclude/petscsys.h>
> #include <finclude/petscvec.h>
> #include <finclude/petscdm.h>
>   PetscInt, parameter :: dim = 3, dof = 1
>   MPI_Comm :: comm
>   DM :: dm, dist_dm, ghost_dm
>   PetscErrorCode :: ierr
>   character(40) :: filename = "column.exo"
>   PetscInt :: localsize
>   PetscFV :: fvm
>   PetscDS :: ds
>   Vec :: X
>   call PetscInitialize(PETSC_NULL_CHARACTER, ierr); CHKERRQ(ierr)
>   comm = PETSC_COMM_WORLD
>   call DMPlexCreateExodusFromFile(comm, filename, PETSC_TRUE, dm, ierr);
> CHKERRQ(ierr)
>   call DMPlexSetAdjacencyUseCone(dm, PETSC_TRUE, ierr); CHKERRQ(ierr)
>   call DMPlexSetAdjacencyUseClosure(dm, PETSC_FALSE, ierr); CHKERRQ(ierr)
>   call DMPlexDistribute(dm, 0, PETSC_NULL_OBJECT, dist_dm, ierr)
>   CHKERRQ(ierr)
>   if (dist_dm /= 0) then
>      call DMDestroy(dm, ierr); CHKERRQ(ierr)
>      dm = dist_dm
>   end if
>   call DMPlexConstructGhostCells(dm, PETSC_NULL_CHARACTER,
> PETSC_NULL_INTEGER, &
>        ghost_dm, ierr); CHKERRQ(ierr)
>   if (ghost_dm /= 0) then
>      call DMDestroy(dm, ierr); CHKERRQ(ierr);
>      dm = ghost_dm
>   end if
>   call DMView(dm, PETSC_VIEWER_STDOUT_WORLD, ierr); CHKERRQ(ierr)
>   call PetscFVCreate(comm, fvm, ierr); CHKERRQ(ierr)
>   call PetscFVSetNumComponents(fvm, dof, ierr); CHKERRQ(ierr)
>   call PetscFVSetSpatialDimension(fvm, dim, ierr); CHKERRQ(ierr)
>   call DMGetDS(dm, ds, ierr); CHKERRQ(ierr)
>   call PetscDSAddDiscretization(ds, fvm, ierr); CHKERRQ(ierr)
>   call DMCreateGlobalVector(dm, X, ierr); CHKERRQ(ierr)
>   call VecGetLocalSize(X, localsize, ierr); CHKERRQ(ierr);
>   print *, "Local size:", localsize
>   call PetscFinalize(ierr); CHKERRQ(ierr)
> end program testplex
> Dr Adrian Croucher
> Senior Research Fellow
> Department of Engineering Science
> University of Auckland, New Zealand
> email: a.croucher at auckland.ac.nz
> tel: +64 (0)9 923 84611
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141128/b5df95a9/attachment.html>
