[petsc-dev] build of manual
Tue Nov 4 15:09:52 CST 2014
On Tue, 4 Nov 2014, Barry Smith wrote:
> > On Nov 4, 2014, at 2:41 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > Thanks Satish,  and I do see this in the web page:
> > make alldoc LOC=${PETSC_DIR}
> > This takes a long time.
>    Yes a very long time
Or just do the part I mentioned in my e-mail. (i.e a part of 'alldoc1')
> >  Is the workflow edit part2.tex; make alldoc … ?
>   No, once you have done the make alldoc once you can simply run make manual.pdf in the manual directory as you edit the users manual.
i.e the following command:
        -cd src/docs/tex/manual; ${OMAKE} manual.pdf LOC=${LOC}
Note: LOC=$PETSC_DIR
Satish
>    Barry
> > On Tue, Nov 4, 2014 at 2:52 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > You'll have to do 'make alldoc1' from PETSC_DIR - or atleast
> > part of it..
> > alldoc1: chk_loc deletemanualpages chk_concepts_dir
> >         -${PYTHON} bin/maint/countpetsccits.py
> >         -${OMAKE} ACTION=manualpages_buildcite tree_basic LOC=${LOC}
> >         - at sed -e s%man+../%man+manualpages/% ${LOC}/docs/manualpages/manualpages.cit > ${LOC}/docs/manualpages/htmlmap
> >         - at cat ${PETSC_DIR}/src/docs/mpi.www.index >> ${LOC}/docs/manualpages/htmlmap
> > Satish
> > On Tue, 4 Nov 2014, Mark Adams wrote:
> > > I get this error when I try to make the manual:
> > > 14:47 mark/gamgdoc ~/Codes/petsc/src/docs/tex/manual$ latex manual.tex
> > > This is pdfTeX, Version 3.14159265-2.6-1.40.15 (TeX Live 2014) (preloaded
> > > format=latex)
> > >  restricted \write18 enabled.
> > > entering extended mode
> > > (./manual.tex
> > > LaTeX2e <2014/05/01>
> > > Babel <3.9k> and hyphenation patterns for 78 languages loaded.
> > >  [snip]
> > > (/usr/local/texlive/2014/texmf-dist/tex/generic/pgf/frontendlayer/tikz/librarie
> > > s/tikzlibrarytopaths.code.tex))) (../sty/verbatim.sty
> > > Style-Option: `verbatim' v1.4d <91/04/24> (RmS)
> > > English Documentation          <91/04/24> (RmS)
> > > ) (../sty/tpage.sty) (../sty/here.sty) (../sty/anlhelper.sty)
> > > (../sty/trl.sty
> > > LaTeX Warning: You have requested package `../sty/trl',
> > >                but the package provides `trl'.
> > > ! LaTeX Error: Missing \begin{document}.
> > > See the LaTeX manual or LaTeX Companion for explanation.
> > > Type  H <return>  for immediate help.
> > > l.38 h
> > >       yperbaseurl
> > > On Tue, Nov 4, 2014 at 2:38 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > >   This is not enough information to help debug your problem.
> > > > > On Nov 4, 2014, at 1:26 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > > > > I am getting errors building the manual and had to comment this out:
> > > > > %hyperbaseurl
> > > > > And I now get this error:
> > > > > ! LaTeX Error: File `part1tmp.tex' not found.
> > > > > Mark
