[petsc-dev] build of manual
Tue Nov 4 15:03:07 CST 2014
> On Nov 4, 2014, at 2:41 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Thanks Satish,  and I do see this in the web page:
> make alldoc LOC=${PETSC_DIR}
> This takes a long time.
   Yes a very long time
>  Is the workflow edit part2.tex; make alldoc … ?
  No, once you have done the make alldoc once you can simply run make manual.pdf in the manual directory as you edit the users manual.
   Barry
> On Tue, Nov 4, 2014 at 2:52 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> You'll have to do 'make alldoc1' from PETSC_DIR - or atleast
> part of it..
> alldoc1: chk_loc deletemanualpages chk_concepts_dir
>         -${PYTHON} bin/maint/countpetsccits.py
>         -${OMAKE} ACTION=manualpages_buildcite tree_basic LOC=${LOC}
>         - at sed -e s%man+../%man+manualpages/% ${LOC}/docs/manualpages/manualpages.cit > ${LOC}/docs/manualpages/htmlmap
>         - at cat ${PETSC_DIR}/src/docs/mpi.www.index >> ${LOC}/docs/manualpages/htmlmap
>         -cd src/docs/tex/manual; ${OMAKE} manual.pdf LOC=${LOC}
> Satish
> On Tue, 4 Nov 2014, Mark Adams wrote:
> > I get this error when I try to make the manual:
> > 14:47 mark/gamgdoc ~/Codes/petsc/src/docs/tex/manual$ latex manual.tex
> > This is pdfTeX, Version 3.14159265-2.6-1.40.15 (TeX Live 2014) (preloaded
> > format=latex)
> >  restricted \write18 enabled.
> > entering extended mode
> > (./manual.tex
> > LaTeX2e <2014/05/01>
> > Babel <3.9k> and hyphenation patterns for 78 languages loaded.
> >  [snip]
> > (/usr/local/texlive/2014/texmf-dist/tex/generic/pgf/frontendlayer/tikz/librarie
> > s/tikzlibrarytopaths.code.tex))) (../sty/verbatim.sty
> > Style-Option: `verbatim' v1.4d <91/04/24> (RmS)
> > English Documentation          <91/04/24> (RmS)
> > ) (../sty/tpage.sty) (../sty/here.sty) (../sty/anlhelper.sty)
> > (../sty/trl.sty
> > LaTeX Warning: You have requested package `../sty/trl',
> >                but the package provides `trl'.
> > ! LaTeX Error: Missing \begin{document}.
> > See the LaTeX manual or LaTeX Companion for explanation.
> > Type  H <return>  for immediate help.
> > l.38 h
> >       yperbaseurl
> > On Tue, Nov 4, 2014 at 2:38 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > >   This is not enough information to help debug your problem.
> > > > On Nov 4, 2014, at 1:26 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > > > I am getting errors building the manual and had to comment this out:
> > > > %hyperbaseurl
> > > > And I now get this error:
> > > > ! LaTeX Error: File `part1tmp.tex' not found.
> > > > Mark
