[petsc-dev] outstanding requests for PETSc fixes need to be fixed before release
Wed May 21 15:35:25 CDT 2014
On Wed, May 21, 2014 at 2:50 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    Thanks
> Feb  9 16:38    Matt volunteered to fix. MatAssemblyEnd hangs during a
> parallel calculation do to preallocation specifics
>  Apr 30 06:0    Matt, fix handling of =97search-dirs in base.py if user
> passes in a string instead of list
This is in master.
   Matt
> May 14 15:54    Satish   have ./configure check and add the argument
> ffree-line-length-none when setting up the Fortran compiler
> Jan 19 19:12    Satish  allow use of environmental variables to set
> ./configure options flag is passed to mange this
> Feb 28 10:53    Satish  make includegraph run in nightly tests and results
> linked into dashboard
> Feb  8 09:35    Satish fix Windows to display 2 digit exponents not three
>  Feb 26 21:5    Satish make findvisibleprivatefunctions in nightly and
> daily tests
> May 16 13:18    Satish,    Please get the src/docs/doxygen/manual/
> directory out of the repository
> Jan 22 21:52    Satish,  if CLAGS contains a -O    CXXFLAGS contains a -O
> FFLAGS contains a -O then turn off PETSc generation of optimization --
> Apr 27 11:00    Satish, add a DMDACoor2d and 3d for Fortran.
> May 16 10:49    Satish, please add ISColoringValue to Fortran include;
> note that its value is configure assigned on the C side.
> Mar 30 18:46    Satish,Jed  remove identical -lxxx listed next to each
> other in toStringNoDupes
> May  7 21:24    Satish,Jed  when =97prefix is provided make sure PETSc
> shared libraries point to updated location of external package
> Mar 20 15:29    balay Please make sure --download-parms  is tested in a
> nightly build
> Mar 25 20:22    someone   write custom stubs for XXXViewSetFromOptions()
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140521/8397d73f/attachment.html>
