[petsc-dev] outstanding requests for PETSc fixes need to be fixed before release
Wed May 21 14:50:10 CDT 2014
   Thanks
Feb  9 16:38    Matt volunteered to fix. MatAssemblyEnd hangs during a parallel calculation do to preallocation specifics
 Apr 30 06:0    Matt, fix handling of =97search-dirs in base.py if user passes in a string instead of list
May 14 15:54    Satish   have ./configure check and add the argument ffree-line-length-none when setting up the Fortran compiler
Jan 19 19:12    Satish  allow use of environmental variables to set ./configure options flag is passed to mange this
Feb 28 10:53    Satish  make includegraph run in nightly tests and results linked into dashboard
Feb  8 09:35    Satish fix Windows to display 2 digit exponents not three
 Feb 26 21:5    Satish make findvisibleprivatefunctions in nightly and daily tests
May 16 13:18    Satish,    Please get the src/docs/doxygen/manual/   directory out of the repository
Jan 22 21:52    Satish,  if CLAGS contains a -O    CXXFLAGS contains a -O FFLAGS contains a -O then turn off PETSc generation of optimization --
Apr 27 11:00    Satish, add a DMDACoor2d and 3d for Fortran.
May 16 10:49    Satish, please add ISColoringValue to Fortran include; note that its value is configure assigned on the C side.
Mar 30 18:46    Satish,Jed  remove identical -lxxx listed next to each other in toStringNoDupes
May  7 21:24    Satish,Jed  when =97prefix is provided make sure PETSc shared libraries point to updated location of external package
Mar 20 15:29    balay Please make sure --download-parms  is tested in a nightly build
Mar 25 20:22    someone   write custom stubs for XXXViewSetFromOptions()
