[petsc-dev] making DA more light weight
Thu May 15 20:14:56 CDT 2014
On May 15, 2014, at 8:01 PM, Jed Brown <jed at jedbrown.org> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>>> I suggest the following:
>>>>   ISLocalToGlobalCreate() takes a block size.
>>>>   ISLocalToGlobalApply() will then do the integer arithmetic if bs > 1
>>>>   ISLocalToGlobalApplyBlock() will just use the given indices
>>>>  Then Mat/VecSetLocalToGlobal() will only have one mapping and DMDACreate() will only create the block version
>>> That's what I meant in my other mail (rationalizing that integer
>>> division should not ruin performance; needs to be tested).
>>    Yes I know it is what you said, I was just laying out in more detail the API changes.
> Perfect.
>>> I think this
>>> is worthwhile and not hard, but it's small fish compared to VecScatter,
>>> which requires several times as much memory.
>>    Not true
>>> See my other mail with
>>> full stack traces for each large allocation.
>>    See my other email where I explained that since you ran in the debugger on one process you got very different results then you would get on two processes.
> Not true, it was a 2-process run.
  But with a dof that is not handled as a bs > 1 hence did not have the memory optimization.
   Barry
