[petsc-dev] making DA more light weight
Jed Brown jed at jedbrown.org
Thu May 15 20:01:06 CDT 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
>>>  I suggest the following:
>>>    ISLocalToGlobalCreate() takes a block size.
>>>    ISLocalToGlobalApply() will then do the integer arithmetic if bs > 1
>>>    ISLocalToGlobalApplyBlock() will just use the given indices
>>>   Then Mat/VecSetLocalToGlobal() will only have one mapping and DMDACreate() will only create the block version
>> That's what I meant in my other mail (rationalizing that integer
>> division should not ruin performance; needs to be tested).
>     Yes I know it is what you said, I was just laying out in more detail the API changes.
Perfect.
>>  I think this
>> is worthwhile and not hard, but it's small fish compared to VecScatter,
>> which requires several times as much memory.
>     Not true
>> See my other mail with
>> full stack traces for each large allocation.
>     See my other email where I explained that since you ran in the debugger on one process you got very different results then you would get on two processes.
Not true, it was a 2-process run.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140515/16b365b3/attachment.sig>
