[petsc-dev] workflow diagram
Thu May 1 11:13:53 CDT 2014
On Thu, 1 May 2014, Satish Balay wrote:
> https://docs.google.com/drawings/d/1kMHa7O6FB5iiJG5QPTWqlMne1xv17A6jOXXyQ_74kaE/edit?usp=sharing
I think I'm done with the edits.
Perhaps there are lurking bugs. I've enabled write access - so anyone
shold be able to fix things.
Jed, Is this ok for your use? [does it still have issues?]. Do you
want to copy this over [or keep it at its current location] - for
further changes?
[perhaps more text (or numbering scheme) is required to explain workflows?]
thanks,
Satish
