[petsc-dev] workflow diagram
Thu May 1 10:25:38 CDT 2014
https://docs.google.com/drawings/d/1kMHa7O6FB5iiJG5QPTWqlMne1xv17A6jOXXyQ_74kaE/edit?usp=sharing
One more change: I've attempted to make the text colors match the
corresponding branch colors.
There are 3 workflows in the 'feature branch' color scheme - so
I've used different text (plain,bold,italic) to distuingish them.
Satish
On Thu, 1 May 2014, Satish Balay wrote:
> I've made some more changes - introduced a couple of notations - and
> attempted to be consistant with symbols and colors.
> And eliminated inconsistancies with some vertical lines (timed
> actions) and some inclined lines(relation between commits).  Now I use
> all vertical lines (i.e timed actions)
> And also added the time-lapse between master & maint [during
> release].
> Perhaps it needs more fixes [Add 'rebase' action for
> un-graduated-before-release branches? Other workflow things?]
> Or - am I headed in the wrong direction [i.e it looks complicated -
> and not simpilfied?]
> thanks,
> Satish
> On Wed, 30 Apr 2014, Satish Balay wrote:
> > Ok - deleted..
> > The operation was refering to the feature/bug-fix branches on the left
> > of it - and the timeline of the release. It overlaped with a
> > 'master->next' dataflow arrow - so I agree it was confusing.
> > [The feature bug fix branches are not represented well anyway - and
> > some arrows are 'parent relations' and others are 'dataflow' - so I'll
> > have to figureout how to better represent/differentiate these..]
> > Satish
> > On Wed, 30 Apr 2014, Barry Smith wrote:
> > >   What does the “delete all graduated branches” box serve? I find it unneeded and confusing. You are just creating a new next based on the current master.  Don’t need that confusing language.
> > >   Barry
> > > On Apr 30, 2014, at 8:25 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > >> On Wed, 30 Apr 2014, Jed Brown wrote:
> > > >>> Satish Balay <balay at mcs.anl.gov> writes:
> > > >>>>> Hmm, feature releases are in first-parent history of both 'maint' and
> > > >>>>> 'master'.  We tag a release on 'master', then do a fast-forward merge of
> > > >>>>> the release tag into 'maint'.
> > > >>>> Ok - updated.
> > > >>> Aesthetically, I like the branches being straight lines, but I think
> > > >>> this still looks like the release tag is not in first-parent history of
> > > >>> 'maint' (like as though there is a no-ff merge).
> > > >> I used vertical lines to convey that master,maint,next at that point are equivalent
> > > > Ok - I added 'action' box to indicate the ff-merge from master to next.
> > > > Satish
