[petsc-dev] PetscFinalize broken with -options_table ?
Tue Mar 18 22:17:17 CDT 2014
   This looks like a problem unrelated to viewers, options,  etc.
   In maint, 3.4.3 and 3.4.4 PetscFinalize() crashes if any PETSc object (like your viewer) is not destroyed before PetscFinalize(). This does not occur in master and is not suppose to happen.
    Trying to track it down but could take a while to determine what change broke this.
   Barry
On Mar 18, 2014, at 6:20 PM, William Perkins <william.perkins at pnnl.gov> wrote:
> All,
> I also ran into this today.
> Attached is a minimal program that exhibited the problem for me. Initially, I thought it was because I was using non-default formats (e.g. MATLAB) for VecView and MatView, but I think any Viewer use causes the problem.
> Thanks.
> Bill
> P.S. I'm using 3.4.3 configured as follows:
> python ./config/configure.py \
>    PETSC_ARCH=arch-macosx-complex-opt \
>    --with-prefix="$prefix" \
>    --with-mpi=1 \
>    --with-cc=mpicc \
>    --with-fc=mpif90 \
>    --with-cxx=mpicxx \
>    --with-c++-support=1 \
>    --with-c-support=0 \
>    --with-fortran=0 \
>    --with-scalar-type=complex \
>    --with-fortran-kernels=generic \
>    --with-valgrind=0 \
>    --download-superlu_dist \
>    --download-parmetis \
>    --download-metis \
>    --download-f2cblaslapack=1 \
>    --with-clanguage=c++ \
>    --with-shared-libraries=0 \
>    --with-dynamic-loading=0 \
>    --with-x=0 \
>    --with-mpirun=mpiexec \
>    --with-mpiexec=mpiexec \
>    --with-debugging=0
> On 03/12/2014 04:30 AM, Matthew Knepley wrote:
>> On Wed, Mar 12, 2014 at 4:52 AM, Václav Hapla <vaclav.hapla at vsb.cz
>> <mailto:vaclav.hapla at vsb.cz>> wrote:
>>    You're right this is not happening with the petsc example. Thus it's
>>    probably problem in my code. I'll come back when I know what's the
>>    true reason.
>> It could still be our bug. If you can strip down your code and send it,
>> I will look at it.
>>   Thanks,
>>      Matt
>>    Matt, sorry for replying to your personal address only.
>>    Thank you,
>>    Vaclav
>>    Dne 11.3.2014 16:04, Matthew Knepley napsal(a):
>>>    On Tue, Mar 11, 2014 at 9:27 AM, Václav Hapla <vaclav.hapla at vsb.cz
>>>        FWICS PetscFinalize in petsc-current contains the following bug.
>>>        It calls
>>>           PetscObjectRegisterDestroyAll()
>>>        and after that, if -options_table is present, it calls
>>>        PetscViewerASCIIGetStdout(PETSC_COMM_WORLD,&viewer);
>>>           PetscOptionsView(viewer);
>>>        causing
>>>           [0]PETSC ERROR: No support for this operation for this
>>>        object type!
>>>           [0]PETSC ERROR: Only supports ASCII viewer!
>>>        because the viewer is destroyed already by
>>>        PetscObjectRegisterDestroyAll.
>>>        I haven't tested petsc-dev but I can see in it's the same
>>>        situation in the pinit.c source.
>>>    I cannot reproduce this on 'next':
>>>    next $:/PETSc3/petsc/petsc-dev/src/snes/examples/tutorials$ ./ex19
>>>    -options_table -snes_monitor
>>>    PETSC_OPTIONS="-cublas 0" ./ex19 -options_table -snes_monitor
>>>    lid velocity = 0.0625, prandtl # = 1, grashof # = 1
>>>      0 SNES Function norm 2.391552133017e-01
>>>      1 SNES Function norm 6.839858507066e-05
>>>      2 SNES Function norm 8.558777232425e-11
>>>    Number of SNES iterations = 2
>>>    #PETSc Option Table entries:
>>>    -options_table
>>>    -snes_monitor
>>>    #End of PETSc Option Table entries
>>>    Can you reproduce this with a PETSc example?
>>>      Thanks,
>>>         Matt
>>>        Best regards,
>>>        Vaclav
>>>        Vaclav Hapla
>>>        Junior researcher / PhD student
>>>        IT4Innovations <http://www.it4i.eu/> / Dept. of Applied
>>>        Mathematics <http://am.vsb.cz/>
>>>        _office PI 328_
>>>        tel.: (+420) 597 329 078 <tel:%28%2B420%29%20597%20329%20078>
>>>        Podnikatelsky inkubator VSB-TUO
>>>        Studentska 6202/17
>>>        708 00 Ostrava-Poruba
>>>        Czech Republic
>>>        _contact address_
>>>        IT4Innovations
>>>        VSB - Technical University of Ostrava
>>>        17. listopadu 15/2172
>>>        708 33 Ostrava-Poruba
>>>        Czech Republic
>>>    What most experimenters take for granted before they begin their
>>>    experiments is infinitely more interesting than any results to
>>>    which their experiments lead.
>>>    -- Norbert Wiener
>>    Vaclav Hapla
>>    IT4Innovations <http://www.it4i.eu/> / Dept. of Applied Mathematics
>>    <http://am.vsb.cz/>
>>    _office PI 328_
>>    Studentska 6202/17
>>    Czech Republic
>>    _contact address_
>>    IT4Innovations
>>    Czech Republic
>> experiments is infinitely more interesting than any results to which
>> -- Norbert Wiener
> Bill Perkins
> Research Engineer
> Hydrology Group
> Pacific Northwest National Laboratory
> 902 Battelle Boulevard
> P.O. Box 999, MSIN K9-36
> Richland, WA  99352 USA
> Tel:  509-372-6131
> Fax: 509-372-6089
> www.pnnl.gov
> <viewer.cpp><viewer.out>
