[petsc-dev] [GPU] src/ksp/ksp/examples/tutorials/ex9 fails with mpirun -np 2
Projet_TRIOU triou at cea.fr
Wed Jul 30 02:15:56 CDT 2014
Hi Karl,
Here is the modified ex30.c and a matrix. In the code, you will see
a flag *use_vecset_to_avoid_crash_on_gpu *set to 0.
mpiexec -np 1 ./ex30 -f0 Matrix_63_rows_1_cpus.petsc -pc_type none
Fill b with VecSetValues
Fill x with VecSetValues
   Number of iterations = 169
   Residual norm 0.00278758
mpiexec -np 2 ./ex30 -f0 Matrix_63_rows_1_cpus.petsc -pc_type none
   Number of iterations = 108
   Residual norm 0.00133484
-mat_type aijcusp -vec_type cusp
   Residual norm 0.00278986
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC
ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to
find memory corruption errors
If you set *use_vecset_to_avoid_crash_on_gpu* set to 1:
Fill x with VecSet
   Residual norm 0.00135365
Thanks, ask me if you need more details, I am using petsc-dev:
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options:
--prefix=/work/triou/Version_test_laramon/Trio_U/lib/src/LIBPETSC/petsc/linux_opt
--with-single-library --with-shared-libraries=0 --with-debugging=0
--with-errorchecking=1 --COPTFLAGS="   -O3 -fPIC " --CXXOPTFLAGS="   -O3
-fPIC " --FOPTFLAGS="  -O3 -fPIC " --with-fortran=yes --with-clean=1
--download-scalapack=../scalapack-2.0.2.tgz
--download-mumps=../MUMPS_4.10.0-p3.tar.gz
--download-superlu_dist=../superlu_dist_3.3.tar.gz
--download-suitesparse=../SuiteSparse-4.2.1.tar.gz
--download-pastix=../pastix_release_3725.tar.bz2
--download-parmetis=../parmetis-4.0.2-p5.tar.gz
--download-metis=../metis-5.0.2-p3.tar.gz
--download-ptscotch=../ptscotch.tar.gz
--download-hypre=../hypre-2.9.1a.tar.gz
--with-valgrind-include=/work/triou/Version_test_laramon/Trio_U/exec/valgrind/include
--with-blas-lapack-dir=/work/triou/Version_test_laramon/Trio_U/lib/src/LIBLAPACK
--with-cuda=1
--with-cuda-dir=/work/triou/Version_test_laramon/Trio_U/exec/cuda5.5
--with-cusp=1
--with-cusp-dir=/work/triou/Version_test_laramon/Trio_U/lib/src/LIBPETSC/cusplibrary-0.4.0
--with-thrust=1 --with-cuda-arch=sm_21 --with-ssl=0
--with-mpi-dir=/work/triou/Version_test_laramon/Trio_U/lib/src/LIBMPI/openmpi
--with-x=1
Libraries compiled on Tue Jul 29 19:21:34 2014 on laramon
Machine characteristics:
Linux-2.6.31.14-desktop-1mnb-x86_64-Intel-R-_Xeon-R-_CPU___________X5650__ at _2.67GHz-with-mandrake-2010.0-Official
Using PETSc directory:
/work/triou/Version_test_laramon/Trio_U/lib/src/LIBPETSC/petsc-dev
Using PETSc arch: linux_opt
Using C compiler:
/work/triou/Version_test_laramon/Trio_U/lib/src/LIBMPI/openmpi/bin/mpicc
-Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O3
-fPIC  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler:
/work/triou/Version_test_laramon/Trio_U/lib/src/LIBMPI/openmpi/bin/mpif90 -Wall
-Wno-unused-variable -ffree-line-length-0 -O3 -fPIC ${FOPTFLAGS} ${FFLAGS}
Using include paths:
-I/work/triou/Version_test_laramon/Trio_U/lib/src/LIBPETSC/petsc-dev/linux_opt/include
-I/work/triou/Version_test_laramon/Trio_U/lib/src/LIBPETSC/petsc-dev/include
-I/work/triou/Version_test_laramon/Trio_U/exec/cuda5.5/include
-I/work/triou/Version_test_laramon/Trio_U/lib/src/LIBPETSC/cusplibrary-0.4.0/
-I/work/triou/Version_test_laramon/Trio_U/lib/src/LIBPETSC/cusplibrary-0.4.0/include
-I/work/triou/Version_test_laramon/Trio_U/lib/src/LIBMPI/openmpi/include
Using C linker:
Using Fortran linker:
Using libraries:
-Wl,-rpath,/work/triou/Version_test_laramon/Trio_U/lib/src/LIBPETSC/petsc-dev/linux_opt/lib
-L/work/triou/Version_test_laramon/Trio_U/lib/src/LIBPETSC/petsc-dev/linux_opt/lib
-lpetsc
-lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack
-lsuperlu_dist_3.3 -lHYPRE
-L/work/triou/Version_test_laramon/Trio_U/lib/src/LIBMPI/openmpi/lib
-L/usr/lib/gcc/x86_64-manbo-linux-gnu/4.4.1 -lstdc++ -lpastix -lumfpack
-lklu -lcholmod -lbtf -lccolamd -lcolamd -lcamd -lamd
-lsuitesparseconfig
-Wl,-rpath,/work/triou/Version_test_laramon/Trio_U/lib/src/LIBLAPACK
-L/work/triou/Version_test_laramon/Trio_U/lib/src/LIBLAPACK -llapack
-lblas -lparmetis -lmetis -lX11 -lpthread -lptesmumps -lptscotch
-lptscotcherr
-Wl,-rpath,/work/triou/Version_test_laramon/Trio_U/exec/cuda5.5/lib64
-L/work/triou/Version_test_laramon/Trio_U/exec/cuda5.5/lib64 -lcufft
-lcublas -lcudart -lcusparse -lmpi_f90 -lgfortran -lm -lstdc++ -lrt -lm
-lrt -lm -lz -lstdc++ -ldl -lmpi_f77 -lmpi -lopen-rte -lopen-pal -lnsl
-lutil -lgcc_s -lpthread -ldl
Pierre
> Hi Pierre,
> Dominic Meiser created a couple of pull requests on GPU usage with
> multiple processes (https://bitbucket.org/petsc/petsc/pull-requests).
> I'll work through them in the next few days, so chances are good that
> this fixes your problem as well. I'll ping you when it's ready. Can
> you send me your modified ex30.c nevertheless?
> Best regards,
> Karli
> On 07/29/2014 05:09 PM, Projet_TRIOU wrote:
>> Yes Matt, I am calling VecAssemblyBegin/End() after VecSetValues.
>> What brings me this idea is the ex30 exercice in
>> src/ksp/ksp/examples/tests/ex30.c
>> where there was the read of a matrix, then VecSet, then VecSetValues
>> eventually
>> (and it was working on GPU with mpiexec -np 2 ...). I played a lot with
>> it to discover
>> VecSet was a turnaround to fix the crash of VecSetValues.
>> I can send my modified ex30.c test to reproduce the bug.
>> Pierre
>>> On Tue, Jul 29, 2014 at 9:58 AM, Projet_TRIOU <triou at cea.fr
>>> <mailto:triou at cea.fr>> wrote:
>>>     Hello Karl,
>>>     For your interest, I understood why my code crashes on GPU with np
>>>     CPUs > 1.
>>>     I am solving Ax=B with KSPSetInitialGuessNonzero set to true so
>>> I need
>>>     also to fill x with VecSetValues before each solve.
>>>     VecSetValues works on GPU with np=1 but not for np>1. I noticed
>>>     that filling
>>>     x with VecSet worked fine so when I create x, I now initialize
>>>     also with VecSet.
>>>     (I suppose it copy/create something on GPU that VecSetValues
>>> doesn't):
>>>     Vec x;
>>>     VecCreate(PETSC_COMM_WORLD,&x);
>>>     VecSetSizes(x, nb_rows_, PETSC_DECIDE);
>>>     VecSetType(x, VECMPICUSP);
>>>     VecSet(x,0.0); // Needed on GPU during parallel calculation, else
>>>     it crashes
>>>     // Later:
>>>     for (int i=0; i<size; i++)
>>>             VecSetValues(b, 1, &colonne_globale, &secmem(i),
>>>     INSERT_VALUES);
>>>             VecSetValues(x, 1, &colonne_globale, &solution(i),
>>>     INSERT_VALUES);
>>>             colonne_globale++;
>>> Are you calling VecAssemblyBegin/End() after this? It is required for
>>> VecSetValues().
>>>    Matt
>>>     Thanks for your help,
>>>     Pierre
>>>>     Thanks Karl, and sorry for my mistake. Indeed, ex9 runs in //
>>>>     with -pc_type none or -pc_type jacobi.
>>>>     Good to know I have an example now with VecSetValues I can try to
>>>>     replicate in my code.
>>>>     I will update the thread as soon as I return to some more tests
>>>>     on it.
>>>>     Pierre
>>>>>     Hi Pierre,
>>>>>     I could reproduce the problem, but I could also verify that the
>>>>>     problem you ran into was due to a currently unsupported
>>>>>     block-Jacobi preconditioner. That is, if you first comment the
>>>>>     KSPSolve for the ksp2 object in ex9, recompile ex9, and then run
>>>>>     $> mpiexec -np 2 ./ex9 -ksp_monitor -mat_type aijcusp -vec_type
>>>>>     cusp -pc_type none
>>>>>     thinks should work out. This may also be applicable to your
>>>>>     case: Give it a try with -pc_type none and let us whether the
>>>>>     problem with VecSetValues remains. (The use of no preconditioner
>>>>>     is certainly not great, but at least it may give you a first
>>>>>     result)
>>>>>     Best regards,
>>>>>     Karli
>>>>>     On 03/26/2014 06:38 PM, Projet_TRIOU wrote:
>>>>>>     Hello all,
>>>>>>     My parallel code is really near to run using GPU device
>>>>>>     thanks to PETSc but I am struggling with the best way
>>>>>>     to fill the PETSc vectors in order in runs on CPU & GPU.
>>>>>>     I was using in the past, VecCreateMPIWithArray, to
>>>>>>     create vector but I had trouble with it on GPU.
>>>>>>     So I followed the example in the
>>>>>>     src/ksp/ksp/examples/tutorials/ex2.c
>>>>>>     and create now the vectors like this:
>>>>>>        // Build x
>>>>>>        ierr = VecCreate(PETSC_COMM_WORLD,&SecondMembrePetsc_);
>>>>>>     check(ierr);
>>>>>>        ierr = VecSetSizes(SecondMembrePetsc_, nb_rows, nb_rows_tot);
>>>>>>     check(ierr);
>>>>>>        ierr = VecSetFromOptions(SecondMembrePetsc_); check(ierr);
>>>>>>        // Build b
>>>>>>        ierr =
>>>>>> VecDuplicate(SecondMembrePetsc_,&SolutionPetsc_);check(ierr);
>>>>>>     And fills it with VecSetValues function. It runs well on CPU and
>>>>>>     GPU but crashed only in parallel on GPU. It I use VecSet
>>>>>>     instead of
>>>>>>     VecSetValues, it didn't crash (but of course VecSet is not
>>>>>> enough
>>>>>>     for me :-)
>>>>>>     I tried to find an example to reproduce for you the problem,
>>>>>> and I
>>>>>>     think src/ksp/ksp/examples/tutorials/ex9 (it is
>>>>>>     usingVecSetValues,)
>>>>>>     is a good one.
>>>>>>     Or did I miss something (I also try
>>>>>> VecPlaceArray/VecRestoreArray
>>>>>>     but without success on GPU) ?
>>>>>>     Thanks, and yes you are right,  "WARNING: Using GPUs
>>>>>>     effectively is
>>>>>>     difficult!" :-)
>>>>>>     Pierre
>>>>>> sitre.intra.cea.fr:/work/triou/git/petsc-dev/Trio_U/lib/src/LIBPETSC/petsc/linux_opt/src/ksp/ksp/examples/tutorials
>>>>>>      > ./ex9 -ksp_monitor
>>>>>>        0 KSP Residual norm 6.612932697792e+00
>>>>>>        1 KSP Residual norm 4.261830032389e-01
>>>>>>        2 KSP Residual norm 2.121746090851e-02
>>>>>>        3 KSP Residual norm 1.233779841608e-03
>>>>>>        4 KSP Residual norm 1.265903168531e-05
>>>>>>        0 KSP Residual norm 1.309416176382e-05
>>>>>>        0 KSP Residual norm 1.404919664063e-05
>>>>>>        0 KSP Residual norm 2.496821857304e+02
>>>>>>        1 KSP Residual norm 4.522206074831e+01
>>>>>>        2 KSP Residual norm 1.959482408314e+01
>>>>>>        3 KSP Residual norm 7.002013703407e+00
>>>>>>        4 KSP Residual norm 2.144105201713e+00
>>>>>>        5 KSP Residual norm 1.780095080270e-01
>>>>>>        6 KSP Residual norm 5.642702243268e-02
>>>>>>        7 KSP Residual norm 6.439343992306e-03
>>>>>>        8 KSP Residual norm 3.012756374415e-04
>>>>>>     Norm of error 0.000249108, Iterations 8
>>>>>>     Norm of error 0.000715584, Iterations 6
>>>>>>        0 KSP Residual norm 3.422287562824e-04
>>>>>>     Norm of error 0.000249108, Iterations 0
>>>>>>     Norm of error 0.000192805, Iterations 7
>>>>>>        0 KSP Residual norm 4.140588954098e-04
>>>>>>     Norm of error 0.000109507, Iterations 7
>>>>>>      > ./ex9 -ksp_monitor -mat_type aijcusp -vec_type cusp
>>>>>>        0 KSP Residual norm 1.309416176403e-05
>>>>>>        0 KSP Residual norm 1.404919664088e-05
>>>>>>     cusp
>>>>>>     [0]PETSC ERROR:
>>>>>>     Violation,
>>>>>>     X to
>>>>>>     [0]PETSC ERROR: configure using --with-debugging=yes,
>>>>>>     recompile, link,
>>>>>>     and run
>>>>>>     [0]PETSC ERROR: to get more information on the crash.
>>>>>>     [0]PETSC ERROR: --------------------- Error Message
>>>>>>     [0]PETSC ERROR: Signal received
>>>>>>     [0]PETSC ERROR: See
>>>>>> http://http://www.mcs.anl.gov/petsc/documentation/faq.html for
>>>>>>     trouble
>>>>>>     shooting.
>>>>>>     [0]PETSC ERROR: Petsc Development GIT revision:
>>>>>>     v3.4.4-3713-g576f62e
>>>>>>     GIT Date: 2014-03-23 15:59:15 -0500
>>>>>>     [0]PETSC ERROR: ./ex9 on a linux_opt named sitre.intra.cea.fr
>>>>>>     <http://sitre.intra.cea.fr> by triou
>>>>>>     Wed Mar 26 18:32:34 2014
>>>>>>     [0]PETSC ERROR: Configure options
>>>>>> --prefix=/work/triou/git/petsc-dev/Trio_U/lib/src/LIBPETSC/petsc/linux_opt
>>>>>> --with-debugging=0
>>>>>>     --CXXOPTFLAGS=" -O3
>>>>>>     --with-clean=1
>>>>>>     --download-superlu_dist=yes
>>>>>>     --download-parmetis=../parmetis-4.0.2-p4.tar.gz
>>>>>> --with-valgrind-include=/work/triou/git/petsc-dev/Trio_U/exec/valgrind/include
>>>>>> --with-blas-lapack-dir=/work/triou/git/petsc-dev/Trio_U/lib/src/LIBLAPACK
>>>>>>     --with-cuda=1
>>>>>> --with-cuda-dir=/work/triou/git/petsc-dev/Trio_U/exec/cuda5.5
>>>>>>     --with-cusp=1
>>>>>> --with-cusp-dir=/work/triou/git/petsc-dev/Trio_U/lib/src/LIBPETSC/cusplibrary-0.4.0
>>>>>> --with-mpi-dir=/work/triou/git/petsc-dev/Trio_U/lib/src/LIBMPI/mpich
>>>>>>     --with-x=1
>>>>>>     [0]PETSC ERROR: #1 User provided function() line 0 in  unknown
>>>>>>     file
>>>>>>     [1]PETSC ERROR:
>>>>>>     [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>     Violation,
>>>>>>     [1]PETSC ERROR: Try option -start_in_debugger or
>>>>>>     [1]PETSC ERROR: or see
>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[1]PETSC
>>>>>>     X to
>>>>>>     [1]PETSC ERROR: configure using --with-debugging=yes,
>>>>>>     recompile, link,
>>>>>>     and run
>>>>>>     [1]PETSC ERROR: application called MPI_Abort(MPI_COMM_WORLD,
>>>>>>     59) - process 0
>>>>>>     [1]PETSC ERROR: --------------------- Error Message
>>>>>>     [1]PETSC ERROR: Signal received
>>>>>>     [1]PETSC ERROR: See
>>>>>>     trouble
>>>>>>     shooting.
>>>>>>     [1]PETSC ERROR: Petsc Development GIT revision:
>>>>>>     [1]PETSC ERROR: ./ex9 on a linux_opt named sitre.intra.cea.fr
>>>>>>     [1]PETSC ERROR: Configure options
>>>>>> --with-debugging=0
>>>>>>     --CXXOPTFLAGS=" -O3
>>>>>>     --with-clean=1
>>>>>>     --with-cuda=1
>>>>>>     --with-cusp=1
>>>>>>     --with-x=1
>>>>>>     [1]PETSC ERROR: #1 User provided function() line 0 in  unknown
>>>>>>     file
>>>>>>     application called MPI_Abort(MPI_COMM_WORLD, 59) - process 1
>>>>>>     *Trio_U support team*
>>>>>>     Marthe ROUX (01 69 08 00 02) Saclay
>>>>>>     Pierre LEDAC (04 38 78 91 49) Grenoble
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> their experiments lead.
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140730/9bc0eb08/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140730/9bc0eb08/attachment.obj>
Type: x-source/x-c
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140730/9bc0eb08/attachment.bin>
