[petsc-dev] PetscSplitReduction
Wed Jul 9 15:29:40 CDT 2014
merged to maint now.
thanks,
Satish
On Tue, 8 Jul 2014, Jose E. Roman wrote:
> El 10/06/2014, a las 10:01, Jose E. Roman escribió:
> > El 08/06/2014, a las 13:13, Jose E. Roman escribió:
> >> El 08/06/2014, a las 12:57, Jed Brown escribió:
> >>> "Jose E. Roman" <jroman at dsic.upv.es> writes:
> >>>> Would it be too much asking that PetscSplitReduction be available in a
> >>>> public header? (together with the functions PetscSplitReductionGet,
> >>>> PetscSplitReductionEnd, PetscSplitReductionExtend).
> >>> Sounds reasonable to me.  Do you want to prepare a patch?  Otherwise I
> >>> can do it later today.
> >> I would rather leave it to you since you will probably want to add manpages for the three mentioned functions.
> >> Thanks.
> > I started with this:
> > https://bitbucket.org/petsc/petsc/commits/e8058a0
> > You may want to namespace SRState and add manpages.
> > Jose
> Can you add this for the next patch release?
> Thanks.
> Jose
