[petsc-dev] PetscSplitReduction
Jose E. Roman jroman at dsic.upv.es
Tue Jul 8 12:36:36 CDT 2014
El 10/06/2014, a las 10:01, Jose E. Roman escribió:
> El 08/06/2014, a las 13:13, Jose E. Roman escribió:
>> El 08/06/2014, a las 12:57, Jed Brown escribió:
>>> "Jose E. Roman" <jroman at dsic.upv.es> writes:
>>>> Would it be too much asking that PetscSplitReduction be available in a
>>>> public header? (together with the functions PetscSplitReductionGet,
>>>> PetscSplitReductionEnd, PetscSplitReductionExtend).
>>> Sounds reasonable to me.  Do you want to prepare a patch?  Otherwise I
>>> can do it later today.
>> I would rather leave it to you since you will probably want to add manpages for the three mentioned functions.
>> Thanks.
> I started with this:
> https://bitbucket.org/petsc/petsc/commits/e8058a0
> You may want to namespace SRState and add manpages.
> Jose
Can you add this for the next patch release?
Thanks.
Jose
