[petsc-dev] DMplex reader / viewers
Tim Tautges (ANL) tautges at mcs.anl.gov
Wed Jan 22 13:06:00 CST 2014
Ok, message received.  Later.
- tim
On 01/22/2014 01:00 PM, Matthew Knepley wrote:
> On Wed, Jan 22, 2014 at 12:59 PM, Tim Tautges (ANL) <tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>> wrote:
>     That's funny, I was thinking the same about DMPlex. :)
> Maybe you can think that on the moab-dev list.
>     Matt
>     - tim
>     On 01/22/2014 12:45 PM, Matthew Knepley wrote:
>         Tim,
>             I do not consider MOAB a real alternative here.
>                Matt
>         On Wed, Jan 22, 2014 at 12:18 PM, Tim Tautges (ANL) <tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>
>         <mailto:tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>>> wrote:
>              On 01/21/2014 05:58 PM, Gorman, Gerard J wrote:
>                          I am not sure if Exodus has a good solution here. As far as I understand, exodus is inherently
>                          sequential, even
>                          when implemented with HDF5 instead of netcdf. I would also worry about third party support for
>         exodus
>                          files using
>                          HDF5 as their storage format. Exodus has an parallel extension called nemesis, but I can?t
>         figure out
>                          how how
>                          their concept of ghost point and cells works. The documentation on this point is really unclear.
>                  I have to admit I was kind of hoping that ExodusII folks would have come on a bit more on the parallel
>         IO front (I’m
>                  assuming those guys also run large simulations…). That said, I see this as a two stage process: first
>         integrate with
>                  DMPlex as that should give the high level abstraction for read/write to file; secondly extend the family of
>                  readers/writers. At least this way there will be some agility and interoperability between different
>         formats, and it
>                  will not be too disruptive to the application codes when a different formats adopted.
>              My impression is that the ExodusII people are working within the context of code frameworks more than disk file
>              formats to do this, e.g. in Trilinos and Sierra.  I don't think the ExoII file format by itself is very
>         conducive to
>              representing parallel, which is why Nemesis writes an annotation (though, I haven't followed ExoII developments
>              closely since they went open source several years back).
>                          b. Do ?poor man? parallel I/O where each CPU does its own I/O, and possibly create interface
>         matching
>                          files ? la
>                          nemesis or SILO. Maybe, we can save enough information on the parallel layout in order to
>         easily write an
>                          un-partitionner as a post-processor.
>                  I am pretty sure that if we are writing everything in slabs to a HDF5 container we do not have to worry
>         too much
>                  about the parallel layout although some clear optimisations are possible. In the  worst case it is a
>         three stage
>                  process of where we perform a parallel read of the connectivity, scatter/gather for continuous
>         numbering, parallel
>                  repartitioning and subsequent parallel read of remaining data. Importantly, it is at least scalable.
>              We've seen fragmentation with unstructured meshes being a problem too, and you won't escape that even with
>              renumbering (though reading then migrating would address that, at the cost of some additional communication and
>              possibly reading to figure out where things need to go).
>                      Depending on the degree of direct interaction/automation in those interactions between the mesh and
>         Petsc, there
>                      are other options as well.  One that we're developing, based on the MOAB library, can read/write
>         (in serial)
>                      ExodusII, and also supports parallel read/write using its own HDF5-based format.  Parallel I/O
>         robustness
>                      has been
>                      iffy above ~16k procs and 32M-64M hex/tet elements, but for smaller problems it should work.  We're
>         in the
>                      process
>                      of developing direct support for going between a mesh defined with fields (called tags in MOAB) and
>         petsc
>                      vectors.
>                      MOAB has pretty solid support for things like computing sharing and ghosting between procs and
>                      exchanging/reducing
>                      field values on those entities.  Viz is supported either by compiling a VTK/Paraview plugin that
>         pulls the
>                      mesh/fields through MOAB or by translating to VTK (also supported directly from MOAB); Visit also has a
>                      plugin you
>                      can enable.  See http://trac.mcs.anl.gov/____projects/ITAPS/wiki/MOAB
>         <http://trac.mcs.anl.gov/__projects/ITAPS/wiki/MOAB>
>         <http://trac.mcs.anl.gov/projects/ITAPS/wiki/MOAB>> for details of MOAB; the petsc integration stuff
>                      is on a bitbucket branch of petsc owned by Vijay Mahadevan.
>                  Another reason this could be of great interest is that MOAB supports (according to the docs) geometric
>         topology
>                  which
>                  could be used when adapting the mesh on a curved surface for example - another item on my which list.
>              Yes, MOAB's file format can handle definitions of groupings (and relations between the groups) necessary to
>              represent geometric topology.  What you use for the shape evaluation of those geometric surfaces is another
>         question
>              though.  If you're wanting to do that using a reconstructed continuous patch, MOAB has some code to do that
>         too,
>              though it's not as good as the latest stuff in that area (from Jiao at Stony Brook).
>              Is it
>                  integrated to PETSc via the plex or does this essentially replace the functionality of the plex?
>              It's not via plex, but I'm pretty sure all the mesh-related functionality available through plex is available
>              through different API functions in MOAB.
>              Why does it break
>                  down for more than 16k procs?
>              It's a combination of things:
>              - maximizing generality means we're using more than just 2 or 3 tables, because in addition to nodes and
>         elements,
>              we need groupings, whose membership determines whether a group is resident on a given processor, etc, and that
>              strongly affects scaling
>              - that same generality causes us to hit an MPI/IO bug on IBM (though we haven't checked on Q yet to see if
>         that's
>              been addressed, it might have been); we've worked with ANL I/O guys off and on on this, and hope to get
>         back to that
>              on Q soon
>              - we do single file parallel I/O, without any 2-phase (communicate down to I/O nodes then do I/O), and that
>         hits
>              HDF5 pretty hard; we're working with hdfgroup to explore that
>              We haven't done any benchmarking on a Lustre system yet, but I expect that to do worse than IBM, because of
>         the many
>              tables thing (my impression is that Lustre doesn't handle frequent metadata reads well)
>              is it just a case that Lustre gets hammered? What magic sauce is used by high order FEM
>                  codes such as nek500 that can run on ~1m cores?
>              Those codes go for a much more restricted I/O data case, which allows them to specialize and do their own
>              implementation of parallel I/O.  So, Nek5000 has its own implementation of poor man's parallel, they repeat
>         vertices
>              in the file that are logically the same (shared between hexes), and they don't really do subsets.  I think
>         that's
>              great to do if you have to, but I'm still hoping for more support in that direction from general libraries.
>                      libmesh also maintains its own DMlibmesh, but I'm not sure how solid their support for large mesh /
>         parallel
>                      I/O is
>                      (but they've been working on it recently I know).
>                  Are there any other formats that we should be considering? It’s a few years since I tried playing about
>         with CGNS -
>                  at the time its parallel IO was non-existent and I have not seen it being pushed since. XDMF looks
>         interesting as it
>                  is essentially some xml metadata and a HDF5 bucket. Is anyone championing this?
>              Don't know about XDMF.  I know there's been a bunch of work on SILO and its parallel performance fairly
>         recently (3
>              or 4 yrs ago) and it's used heavily inside LLNL.
>              - tim
>                  Cheers Gerard
>              ==============================____============================__==__====
>              "You will keep in perfect peace him whose mind is
>                 steadfast, because he trusts in you."               Isaiah 26:3
>                            Tim Tautges            Argonne National Laboratory
>                        (tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov> <mailto:tautges at mcs.anl.gov
>         <mailto:tautges at mcs.anl.gov>>)      (telecommuting from UW-Madison)
>                phone (gvoice): (608) 354-1459 <tel:%28608%29%20354-1459> <tel:%28608%29%20354-1459>      1500
>         Engineering Dr.
>                           fax: (608) 263-4499 <tel:%28608%29%20263-4499> <tel:%28608%29%20263-4499>      Madison, WI 53706
>         What most experimenters take for granted before they begin their experiments is infinitely more interesting than any
>         results to which their experiments lead.
>         -- Norbert Wiener
>     ==============================__==============================__====
>               (tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>)      (telecommuting from UW-Madison)
>       phone (gvoice): (608) 354-1459 <tel:%28608%29%20354-1459>      1500 Engineering Dr.
>                  fax: (608) 263-4499 <tel:%28608%29%20263-4499>      Madison, WI 53706
> -- Norbert Wiener
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
