[petsc-dev] CFLAGS and COPTFLAGS
Sean Farley sean.michael.farley at gmail.com
Mon Jan 20 14:27:21 CST 2014
bsmith at mcs.anl.gov writes:
> On Jan 20, 2014, at 12:49 PM, Sean Farley <sean.michael.farley at gmail.com> wrote:
>> jed at jedbrown.org writes:
>>> Barry Smith <bsmith at mcs.anl.gov> writes:
>>>>     Where should we put the files that end up in conf? Should we
>>>>     simply not install those?
>>> I don't think we should install logs.  If it were up to me, I would put
>>> the makefiles in $prefix/share/petsc/, but I would install a script
>>> petsc-config that can be used to dump the configuration as well as
>>> provide configuration (a la pkg-config).  I think we should recommend
>>> that users use this petsc-config script instead of including makefiles.
>>> What do you think?
>> Jed's suggestions here would be great for package maintainers. As an
>> added bonus, it'd be great if $prefix/share/petsc-$foo could be be
>> configurable (so that multiple installations could be live
>> side-by-side).
>     This would allow multiple copies of the “share” stuff but if the library is in $prefix/lib/libpetsc.dylib  how can multiple installations exist side by side?
There would have to a configurable subprefix, e.g. include/petsc-3.4,
lib/petsc-3.4, etc. Though, it's not as big a deal to me.
