[petsc-dev] petsc-dev fails test with debugging=0
Andrea Lani andrea.lani at gmail.com
Sun Jan 19 16:00:30 CST 2014
I want to use KSPGMRES
>> Sure, this is the log file for the case with KSPGMRES and PCBJACOBI on 2
>> GPUs.
> Evidently Block Jacobi does not support GPUs because it uses VecPlaceArray.
> What subdomain solver did you want to use?
