[petsc-dev] petsc-dev fails test with debugging=0
Jed Brown jed at jedbrown.org
Sun Jan 19 15:55:39 CST 2014
Andrea Lani <andrea.lani at gmail.com> writes:
> Sure, this is the log file for the case with KSPGMRES and PCBJACOBI on 2
> GPUs.
Evidently Block Jacobi does not support GPUs because it uses VecPlaceArray.
What subdomain solver did you want to use?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140119/c15398d3/attachment.sig>
