[petsc-dev] CFLAGS and COPTFLAGS
Jed Brown
jed at jedbrown.org
Fri Jan 17 17:46:39 CST 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
> I do not understand the context of this email at all.
> Are you referring to putting CFLAGS=-O3 inside a ./configure option?
> If so I see help.addArgument('Compilers', '-CFLAGS=<string>',
> nargs.Arg(None, None, 'Specify the C compiler options’))
If you configure with CFLAGS=-O3 --with-debugging=0, configure will test
the -O flag and ultimately use -O3 -O. The latter takes precedence, so
the -O3 is effectively ignored. To replace the optimization flag, one
is (currently) supposed to use COPTFLAGS=-O3 --with-debugging=0. This
is surprising because COPTFLAGS is not a widespread convention.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140117/245906c3/attachment.sig>
