[petsc-dev] GPU preconditioners
Andrea Lani andrea.lani at gmail.com
Fri Jan 17 13:29:29 CST 2014
Dear Devs,
is the PCBJACOBI solver fully ported to GPU in the latest petsc-dev
version? if not, is there any intention to do so in the near future?
I have a convection-dominated (with strong discontinuities in the flow
field) MHD problem where PCASM and PCBJACOBI both work fine with KSPGMRES.
Looking for a speedup in my code (which is using a petsc-dev version about
two-months old), the only GPU alternative I found was PCJACOBI. This is
indeed considerably faster on GPU, but does not converge (neither does,
consistently, its CPU counterpart) if not for a few iterations before
blowing up. Any other alternative for GPU-based preconditioners or solvers
worth trying at the moment?
Thanks in advance for your advice
Andrea
Dr. Andrea
Lani
Senior Research Engineer, PhD
Aeronautics & Aerospace dept., CFD group
Von Karman Institute for Fluid Dynamics
Chausse de Waterloo 72,
B-1640, Rhode-Saint-Genese,  Belgium
fax  : +32-2-3599600
work : +32-2-3599769
*lani at vki.ac.be <lani at vki.ac.be>*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140117/5e11aae6/attachment.html>
