[petsc-dev] get rid of petscsys.hh?
Thu Jan 2 10:10:22 CST 2014
On Wed, Jan 1, 2014 at 2:10 PM, Barry Smith <barryfsmith at me.com> wrote:
>   Matt,
>    You removed petscsys.hh but also need to remove its dependencies
I don't think we can remove this. I fixed the include.
   Matt
>         CXX arch-pylith-gcc-opt/obj/src/sys/error/err.o
> /Users/buildbot/slave/build/pylith_darwin_10.6_binbot/PETSc/petsc-pylith/binaries/src/sys/error/err.c:
> In function 'void PetscCxxErrorThrow()':
> /Users/buildbot/slave/build/pylith_darwin_10.6_binbot/PETSc/petsc-pylith/binaries/src/sys/error/err.c:304:5:
> error: 'ostringstream' is not a member of 'std'
> /petsc-pylith/binaries/src/sys/error/err.c:304:25: error: 'msg' was not
> declared in this scope
> /Users/buildbot/slave/build/pylith_darwin_10.6_binbot/PETSc/petsc-pylith/binaries/src/sys/error/err.c:305:12:
> /Users/buildbot/slave/build/pylith_darwin_10.6_binbot/PETSc/petsc-pylith/binaries/src/sys/error/err.c:305:31:
> error: expected primary-expression before ')' token
> /Users/buildbot/slave/build/pylith_darwin_10.6_binbot/PETSc/petsc-pylith/binaries/src/sys/error/err.c:305:33:
> error: expected ';' before 'eh'
> /Users/buildbot/slave/build/pylith_darwin_10.6_binbot/PETSc/petsc-pylith/binaries/src/sys/error/err.c:309:9:
> error: 'PETSc' has not been declared
> make[2]: *** [arch-pylith-gcc-opt/obj/src/sys/error/err.o] Error 1
> On Dec 26, 2013, at 2:59 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Thu, Dec 26, 2013 at 2:41 PM, Barry Smith <barryfsmith at me.com> wrote:
> >     Can we get rid of petscsys.hh which still? seems to be lurking in
> master?
> > I will get rid of it.
> >   Matt
> >    Thanks
> >    Barry
> > /* Special support for C++ */
> > #if defined(PETSC_CLANGUAGE_CXX) && defined(__cplusplus)
> > #include <petscsys.hh>
> > #endif
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140102/02bbf728/attachment.html>
