[petsc-dev] get rid of petscsys.hh?
Barry Smith barryfsmith at me.com
Wed Jan 1 14:10:11 CST 2014
  Matt,
   You removed petscsys.hh but also need to remove its dependencies
        CXX arch-pylith-gcc-opt/obj/src/sys/error/err.o
/Users/buildbot/slave/build/pylith_darwin_10.6_binbot/PETSc/petsc-pylith/binaries/src/sys/error/err.c: In function 'void PetscCxxErrorThrow()':
/Users/buildbot/slave/build/pylith_darwin_10.6_binbot/PETSc/petsc-pylith/binaries/src/sys/error/err.c:304:5: error: 'ostringstream' is not a member of 'std'
/petsc-pylith/binaries/src/sys/error/err.c:304:25: error: 'msg' was not declared in this scope
/Users/buildbot/slave/build/pylith_darwin_10.6_binbot/PETSc/petsc-pylith/binaries/src/sys/error/err.c:305:12: error: 'ostringstream' is not a member of 'std'
/Users/buildbot/slave/build/pylith_darwin_10.6_binbot/PETSc/petsc-pylith/binaries/src/sys/error/err.c:305:31: error: expected primary-expression before ')' token
/Users/buildbot/slave/build/pylith_darwin_10.6_binbot/PETSc/petsc-pylith/binaries/src/sys/error/err.c:305:33: error: expected ';' before 'eh'
/Users/buildbot/slave/build/pylith_darwin_10.6_binbot/PETSc/petsc-pylith/binaries/src/sys/error/err.c:309:9: error: 'PETSc' has not been declared
make[2]: *** [arch-pylith-gcc-opt/obj/src/sys/error/err.o] Error 1
On Dec 26, 2013, at 2:59 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Dec 26, 2013 at 2:41 PM, Barry Smith <barryfsmith at me.com> wrote:
>     Can we get rid of petscsys.hh which still? seems to be lurking in master?
> I will get rid of it.
>   Matt
>    Thanks
>    Barry
> /* Special support for C++ */
> #if defined(PETSC_CLANGUAGE_CXX) && defined(__cplusplus)
> #include <petscsys.hh>
> #endif
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
