[petsc-dev] git problem
Wed Feb 26 14:39:18 CST 2014
git pull
git push
should be fine [wrt workflow]
To reset HEAD to previous commit:
git reset --hard HEAD~1
Satish
On Wed, 26 Feb 2014, Barry Smith wrote:
>    I know if I do this I will get yelled at!  So why does git suggest something that will get me yelled at, why doesn’t it suggest something that will make Jed happy? I’m serious
>    BTW: what the f am I suppose to do here.
>    Barry
> To git at bitbucket.org:petsc/petsc.git
>  ! [rejected]        next -> next (fetch first)
> error: failed to push some refs to 'git at bitbucket.org:petsc/petsc.git'
> hint: Updates were rejected because the remote contains work that you do
> hint: not have locally. This is usually caused by another repository pushing
> hint: to the same ref. You may want to first merge the remote changes (e.g.,
> hint: 'git pull') before pushing again.
> hint: See the 'Note about fast-forwards' in 'git push --help' for details.
